cd player help
My single disc cd player in my '99 LC has been randomly rejecting discs for the past month or so, and today it finally just gave out. Any kind of disc I put in is rejected after a second or so. Has this happened to anyone else?
I mostly listen to my plug-and-play Sirius (which isn't affected) so I'm not that bothered, but the proper thing to do is fix it. Any idea on the cost? It's just the cd player and nothing else.
Finally, I know some of you have put navi screens in to replace the whole unit... Would it be worth having done? I guess it ultimately depends on how great of a price difference the repair is to total replacement with navi.
Thanks.
The factory cd changers WILL fail. It is mostly a question of when they will fail.
Many of the used ones for sale on ebay don't work either. I suggest upgrading to an aftermarket unit when you decide to move on.
I also enjoy Sirius. Eventually, I want the Kenwood EZ700SR with built in Sirius receiver to replace my factory junk.
I took my cd player out of my 99 and got it repaired. That did not work. I am saving up for a Kenwood DDX7017. Double DIN, DVD, plays all different cds, ipod input, reverse camera input, tv, etc.
uzj100
May I ask why you are choosing the EZ700SR? I checked it out, and it seems pretty typical of all head units... Does it fit the LC/LX better than the rest, or something? That would be important to me. I don't want some slim head unit that will leave a big gap where the factory unit was.
uzj100
I found one of these for $1,299.99 on Crutchfield's website. Have you found any better priced? I'm definitely considering but the price is a little steep for a '99 that may be replaced soon anyway.
Anyone have any luck using the disc cleaners? I have a disc that is for cleaning the head unit that you just put in the CD like a normal CD and it is suppose to clean the head. Just wondering if it will get me somemore time out of the OEM CD player???
"I took my cd player out of my 99 and got it repaired. That did not work. I am saving up for a Kenwood DDX7017. Double DIN, DVD, plays all different cds, ipod input, reverse camera input, tv, etc.
uzj100"
I bought two of these on ebay for $700.00 each. I installed one in my 80, & one in the 100 that I just sold. They both work great, & I love them. The versatility is awesome & the kenwood navigation is pretty cool. Touchscreen rules!
Lens cleaner CD disc DID not work on my 99 LC.
I am keeping my 99 for some time and if I update it with a ddx7017, the vehicle will have a much more modern feel to it.
uzj100
SWUtah said:
Mine is still working but I do worry about it so I would love to know the cost answer? Do you just go to a sound shop and get a new one?
The Lexus 6disc changer will run you about $1800.00, don't know about the single disc. I had my 6disc changer changer repaired at a place around Atlanta. It ran about $350.00. It was expensive, but it was the cheaper alternative. I will look to see if I can find the name of the shop.
Just my opinion, but other than the Kenwood double-din unit nothing looks anywhere near as good as stock.
Pioneer makes a unit that includes NAV, AVIC-D1, but does not play regular DVDs. Looks more stock than the kenwood.
uzj100
This is where I got mine repaired.
Electronics Master Repairs
Lexus Department
2131 Pleasant Hill Road
Suite 135
Duluth, Georgia 30096-2303
EMRatlanta@msn.com
1-678-957-0686
I would like a wiring harness that plugs in to the back of the ddx7017 and could mounted for easy access, for the ipod inputs and av inputs. That way, when you get in your LC, you plug in the ipod and off you go or if you would like to view video or pictures from a camera or camcorder, you just plug into the AV outlet. That is going to be sweet.
uzj100
CD repair
The CD player in my 2000 LC is doing the same thing. I contacted the local dealership and they want me to bring in the CD player. They in turn are sending it back to the stereo manufacturer to be repaired, Quoted price of $299.00. I believe there is an amp under the pass. seat that may have to be wired past if you put in an aftermarket unit, no big deal just a possibility.
The reason I choose the EZ700SR is because it comes with in integrated (read "built-in") Sirius receiver. Then I can dump the big, ugly, clunky siruis receiver which is sitting on my dash.
Kenwood makes a nice product and this particular model is available on ebay for around $250.
I don't care if it is single din, I'll just fill the space in with an extra plastic holder.
Does siruis use the LC antenna or does it use another recieving source? My antenna is not going up and I don't want to have to deal with that fix if I go to siruis. Plus I live way out in the boondocks, where we don't get many stations. Does siruis reach everywhere??
You will need a sat. antenna, the RF antenna will not work. Sat. radio will work anywhere in the boonies, as long as you are not under anything that will obstruct the signal. Obstructions such as dense trees or a roof.
While you are correct about a separate satellite antenna being required, it should be noted that the FM antenna is what picks up the FM broadcast sent out by the Sirius/XM unit. This is true unless the driver chooses to use the cassette-adapter or the aux-in (which isn't available on a stock LC stereo). When my antenna is fully lowered, I can barely pick up the FM broadcast signal sent out by my Sirius. Therefore, you may need use of your FM antenna to listen to Sirius, unless you choose to use a tape-adapter.
Couple things.
First of all, the specific receiver I'm talking about, the Kenwood EZ700SR has a built in Sirius receiver and it comes with the Satellite antenna.
The existing system I have has an external receiver and picks up the signal then broadcasts it to your FM radio. This sucks.
As far as the content goes, Sirius is very cool with tons of rock stations to choose from.
I loose my signal in parking structures. That is about the only place I loose it.
Now, as far as your antenna goes, is the motor going bad or is the mast broke? Either way, it is not too hard to service yourself.
