CCOT Voltage Regulator produces 15volts
Discussion in '40- & 55-Series Tech' started by WES1977, Aug 9, 2005.
  1. WES1977
    WES1977
    1,790
    Media:
    9
    Albums:
    3
    44
    May 20, 2005
    Chesapeake, VA
    I know this has been discused before but all I can find is good is 13.8- 14 something. Ok here is the story. My electical system is running great on my stock 2F at perfect 13.8 volts and amps look good on the gauge. The stock voltage regulater looks pretty bad with corrosion but works. I bought a voltage regualtor from CCOT (which has no return on electrical parts), installed it and 14.98 volts. Turned the lights on, and it goes slightly over 15 volts. Put the stock regulator back in and back down to 13.8 volts.
    I emailed CCOT yesterday and told them my story, and asked them was it adjustable. I was called at lunch time by CCOT and he told me that 15 amps is good. He kept telling me amps when he should have said volts everytime. :mad: I even corrected him a few times with no sucsuess. He told me I should not worry unless it was like 20 "Amps". He said a little high is good.
    The real question is: Is 15volts to high? Is CCOT :censor: up?
  2. lovetoski
    lovetoski SILVER Star
    4,618
    288
    Jul 13, 2003
    I think the normal range is 13.8 - 14.4 volts. If I recall correctly, over 15 Volts and you start to run the risk of over-charging your battery, which could cause it to boil/blowup/etc (ie - something bad can happen). Don't know if "over" 15 volts means 15.1 or 15.5 though...
    How are you measuring voltage? Is it with an accurate voltmeter?
  3. WES1977
    WES1977
    1,790
    Media:
    9
    Albums:
    3
    44
    May 20, 2005
    Chesapeake, VA
    It never got over 15.1 volts and it is an accurate digital multimeter.
  4. fj40Matt
    fj40Matt
    117
    4
    Jul 6, 2003
    Minnesota
    In my experience the aftermarket regulators are pretty crappy. I'm not sure what CCOT uses, but I've had bad luck with aftermarket parts store versions. You might try getting one from Toyota. Or there's a link in the Tech Links for a solid state regulator that is pretty easy to install.
    You could also try adjusting the regulator if you're feeling adventurous...
  5. WES1977
    WES1977
    1,790
    Media:
    9
    Albums:
    3
    44
    May 20, 2005
    Chesapeake, VA
    Yes I was dumb buying if from CCOT. I don't think I can adjust it. It doesn't look the same as the factory one. It looks like a resister with a screw threw it, so i might try playing with it. What have I got to lose, i've all readly lost my money.
  6. fj40Matt
    fj40Matt
    117
    4
    Jul 6, 2003
    Minnesota
    It doesn't have the removable black cover? The aftermarket ones I had were similar in design to the OE regulator.
    BTW, I've never adjusted one myself. Hopefully you've got a factroy manual there as a guide, because I'll be no help.
  7. WES1977
    WES1977
    1,790
    Media:
    9
    Albums:
    3
    44
    May 20, 2005
    Chesapeake, VA
    I thought on the stock one you adjusted it by rotating the spool that is on the side that mounts to the firewall. It adjust on the inside? It is the same shape just the spool is a resister looking like thing. Maybe I should look at the haynes manual.
  8. Landpimp
    Landpimp
    16,093
    Media:
    1
    2,081
    Mar 14, 2003
    Gig Harbor WA
    new OEM regs from Toyota are really cheap, like under $20, never had a problem with any of the OEM ones I have used.
    they(at least the early ones) can be adjusted from the inside, its like adjusting points.
  9. Godwin
    Godwin Resident Herpetologist SILVER Star
    4,572
    5,939
    Dec 4, 2004
    Alabama
  10. lovetoski
    4,618
    288
    Jul 13, 2003
    The repercussions from poor voltage regulation are significant...and a good OEM voltage regulator is cheap. Just get an OEM Toyota one, and don't look back.
  11. Cruiserdrew
    Cruiserdrew On the way there SILVER Star
    15,587
    4,637
    Mar 15, 2003
    Sacramento, CA
    The ones from Toyota are remans, but the one I have works great and cost about $14. I tried an aftermarket one from SOR first and it didn't work right out of the box. Generally aftermarket stuff from CCoT is not worth having, in my opinion.
  12. ranger
    ranger
    1,169
    7
    Jan 18, 2003
    Mountain Hole, Idaho
    Your first mistake was buying something from CCOT, the next was trying to get customer service. Hard to get good Taiwan parts...........15V is too much it will cook your battery.
  13. WES1977
    WES1977
    1,790
    Media:
    9
    Albums:
    3
    44
    May 20, 2005
    Chesapeake, VA
    Yeah I knew it was to high, and that guy telling me a little high was good. I knew it was a load of crap. I'll ask toyota when I when I go to pick up my new oe regulator. Then i'll tell the custemer service of CCOT what they said, and tell them don't worry about it cause this won't happen again. :flipoff2:
  14. Landpimp
    Landpimp
    16,093
    Media:
    1
    2,081
    Mar 14, 2003
    Gig Harbor WA
    another nice thing about OEM Toyota parts, they all have a 1 year warantee........which I have only used 1-2 times(hood latch and 1 other thing)......in 10 years and 1000's of OEM parts.
  15. ken_79-fj40
    ken_79-fj40
    1,424
    40
    Jul 2, 2002
    New Hampshire
    The first few orders I made with CCOT I was very happy with. But the last few times I have called there I have been unimpressed with the knowledge of the salespeople I have spoken with. And all the aftermarket lights and electrical stuff I have gotten from them has been pretty low quality. You get what you pay for. I have now learned to buy OE the first time. I recently placed an order with Specter (I've never had bad luck with them) because CCOT would not sell me tire carrier bushings. The guy said they don't ever have them. C'mon they restore cruisers and the never have to replace the tire carrier bushings? Right! So CCOT lost out on a few hundred bucks over a $10 item. They had everything else I wanted. And a little cheaper than SOR too.
  16. bj40man
    bj40man
    213
    12
    Sep 17, 2002
    I had problems with my OEM regulator on a BJ42 a had a while back. Checked with the dealership and found out they didn't have the regulator for mine.
    My friendly electrical mechanic offered to replace the bad regulator with an electronic one made by transpo. He put a Transpo F540 made for ford (http://www.transpo.de/Catalog/Browse.htm) and as far as I know it still works like a champ on that bj42. From what I have learned from then, you basically need Field, Ignition and ground. That one he installed had an option to connect a warning light (like newer cars have) but I had no where to put it.
    i hope this helps! :)
  17. Gumby
    Gumby Supamod Staff Member s-Moderator
    12,226
    679
    Dec 13, 2002
    Knee deep in hookers and gin
    15 is on the high side, but not by a lot. You will boil the water out of the battery if it gets too high. It's not going to blow up. 15 might never do anything to a sealed battery. Spec for a 2F engine is 13.8 to 14.8.
    If the regulator is solid state it is not adjustable. If it has moving parts it might be.
