CCOT aftermarket mirror arms
Discussion in '40- & 55-Series Tech' started by chitown40, Mar 15, 2004.
  1. chitown40
    chitown40
    2,109
    22
    Feb 9, 2004
    Buffalo Grove, IL
    My cruiser has two new CCOT aftermarket mirror arms (see pic) and whenever I'm driving over 30 mph they seem to fold inwards. I took apart the arms and tried to shim them up tighter, but I'm still having the problem. Any suggestions how to get them nice and tight?
    Thanks in advance,
    Rob
  2. Frederik
    Frederik
    19
    Oct 10, 2003
    Did you try to tighten the bolts in there (are there any?, I know in mine there are)
    if not, only sollution (IMHO) is to fold the arms tottaly forward and adjust the mirrors so you can see. The (wind)forces on the mirror will cause a minimum turn-effect.
    (I hope I made myself clear, 'cause I'm dutch...)
  3. NJFJ40
    NJFJ40
    462
    Oct 8, 2003
    Near Junk
    Frederick is right - those arms have bolts where they attach to the mount plate - you'll see a spring behind the bolt which compresses and gives you more tension on the arm thus reducing unwanted straying. I torqued mine pretty tight where you almost need two hands just to move the arm. Now no more wind issues. Give it a shot.
    Andy
  4. ahh my PO must have done that NJFJ40.Mine are so tight that it bends before it begins to move! I might take it apart and loosen them up a little cause i dont like where they are posistioned now..
  5. chitown40
    chitown40
    2,109
    22
    Feb 9, 2004
    Buffalo Grove, IL
    Thank you all for your info. I'm pretty sure mine are a little different, as they are aftermarket replicas, but I'll take 'em off and check it again. I'll also post some pics if they are in fact different.
    Tks,
    Rob
