60wag
Since the last club run, I think my CB is having some transmitting problems. It seems to recive ok but the transmit is weak. I got out my RadShack Field Strength/SWR meter. The SWR looks good at about 1.1 to 1.2. I had never tried to measure field strength before but found that the meter had to be within 3-5 feet of the antenna to read anything. This is with the gain knob turned all the way up. The antenna is a cheap 4ft RadShack fiberglass one. I have another mag mount wire antenna. I tried it in the middle of the roof after having set the SWR on it. I got pretty much the same result - the field strength dropped to zero about 5 ft from the antenna. Is this right? The meter instructions rec' measuring field strength at 25ft. The mag mount antenna has its own cable, so I don't think the cable is the problem. I have another old CB that I had retired because its ability to transmit seemed flaky also. It too creates about the same reading on my meter. So do I need a new CB, or am I missing something? The current CB is a Rad shack that is less than three years old. Is transmit failure a common failure in CBs, or just the ones I have?
Bruce
Bruce
