CB question
North Cadillac
Does anyone know if there is a CB that will fit on our ashtray slot? My ashtray is done for and out. NOw i have a big hole and am thinking a CB would be perfect, especially when trying to get in touch with folks at the trails.
wal mart carrys the same sized one and its $34.99 i dont rmember the brand but itll work
concretejungle said:
Thanks gumby i'll go check it out. Do you happen to have a model or part # handy?
Get the smallest radio that radio shack carries. Should be around $40.
I've been using one in the open weather 40 for a while now, no problems.
Lasted longer already than the $110 Radio Shack model did... :mad:
? are you guys really mounting them in the ash tray or are you mounting them below the the radio after you put in an aftermarket radio?
Concrete,
I picked up a new Uniden 510xl on eBay for $12 + shipping. They make a couple of versions of it. Here are the installation instructions on Christo's website.
-B-
Sweet B, thanks.
You don't have your speaker wired into your overhead light do you? That's a little more than i am wanting to do or can do.
Sweet B, thanks.
No, that mod was one that Christo did. I can hear everything fine through the CB speaker that is mounted in the bottom of the CB case. That radio has provisions for an external speaker and some have used the lower dash speakers for the CB. Mine is only used for club runs so rigging up something like that was out of scope for my project.
-B-
Radio Shack TRC-502. No problems on the speaker. I heard Ali all the way home Saturday over the MT/Rs at 70.
i also have a Cobra 19 LTD that is probably a better CB, but it would take enough modification to fit that the ashtray would not go back in if i wanted to sell it.
i have not seen a single DIN installation that was as clean as the ashtray one. The mazda head unit was not as clean, but is a 6 disk in dash that actually plays CDs and is therefore a better one than the stock unit.
I did same as Slee et al. Uniden 510 or 520 will work for you in the ashetray spot. The sepaker in the unit is sufficient. If I was on the intersate on a regular basis I would use the dashe speakers, but for a few trips per year, the speaker in the unit works fine.
Cobra 18WXST II fits into the single din location, just as clean if not cleaner than the Astray (I happen to like my astray). I should hopefully install by SAturday... the pic is complements of "outback."
I stand corrected. That is a very clean install. most I have seen stick out farther than the radio and don't look near as clean.
I would miss my 6 disk and tape player too. i only use the tape for books on tape, my library still has way more on tape than on CD.
I don't miss the ashtray
What's that in the useless cupholder slot?
I think it's an XM player...but not sure...the rig is not mine as I stated it belongs to "OutbacK" or that's who gave me the pic
