Cats, where on 97's? (1 Viewer)
offroadkid
GOLD Star
Shingle Springs, California
I know on my 92 they are under outside the frame YUK!! The 93-? are on the pass. outside of the frame, what about the 97's? Are they inside the frame?
Two cats, in-line, outside the frame.
-B-
Protect them with tube. :flipoff2:
It seems everybody adding sliders work very hard to get around and protect the cats. Is there an aftermarket cat what would sit high enough to fix this problem?
Hey Junk, do the cats still rotate freely on the muffler bearings with that pipework around it, or do you have to remove the bar work first...... ;) :D
Ali cut off his cats and rotated them sideways, however you can only do this with non-oem, aftermarket titanium muffler bearings at a 45 degree angle to the slider. Otherwise the exhaust will interfere with your extended brake line breather whoozywhatsit.....
