Castor correction with " stock " OME springs?
Discussion in '80-Series Tech' started by spartan, Aug 24, 2006.
  1. spartan
    spartan SILVER Star
    1,023
    96
    May 30, 2005
    Secesh
    I know it's a strange one, but I am considering lowering the truck with OME standard height springs. The only catch is that I have the castor correction kit installed. What effect would this have after lowering? I would leave the 30MM front spacers in to level the truck. Shocks would be switched out obviously and the LSPV readjusted. Thoughts?
  2. tech_dog
    tech_dog
    1,146
    6
    Jan 12, 2006
    San Diego
    From Michelin's web site: "Too much caster causes hard steering and can also result in excessive road shock and shimmy."
    I'm not sure how much over adjustment it would take to bring out these symptoms.
  3. cary
    cary
    3,118
    43
    May 7, 2003
    My thought is the 861/862 combo lifts the truck about 3/4" and you are adding another 1-1/4" by using spacers which equals almost 2" of lift. That is not far off the standard medium lift OME springs so the standard caster kit should work great.
  4. -Spike-
    -Spike-
    7,044
    716
    May 26, 2005
    Phoenix
    Make your suspension changes, then take it to an alignment shop. Tell them what's going on, and if they say you have too much caster, replace one or both bushings with stock to obtain the correct caster.
    -Spike
  5. alkaline747trio
    alkaline747trio
    4,577
    13
    Feb 2, 2005
    Albemarle NC
    You can replace the bushings, or have them aligned to give less correction.
  6. bhmmapping
    bhmmapping
    4,094
    244
    Nov 23, 2005
    Birmingham, AL
    could you find another member that has the stock height ome springs who would be willing to swap springs, shocks, and control arms? I might know someone ;)
  7. cruiserdan
    cruiserdan SupportingVendor Emeritus Moderator
    22,314
    6,616
    Mar 27, 2003
    Land Cruiser Heritage Museum broom closet
    This depends entirely on how much caster the vehicle has now. No two 80's have the same caster. You will have to do a caster sweep to determine where it is now before the question can be answered.
  8. spartan
    spartan SILVER Star
    1,023
    96
    May 30, 2005
    Secesh
    I knew you were going to say that.
    These bushings were installed as per the OME instructions without regard to " actual measured " castor changes from the installed lift and the truck seems to be fine. No abnormal tire wear, handling, etc..
    I guess the real test would just be to do it and see what happens.
    Perhaps the best solution would just be to tell my wife - who is the one on the lowering mission because she's pregnant with only two months left to go - that it can't be done cause of the castor correction kit installed with the lift.
    That and our five year old daughter wouldn't know how to get into a vehicle that doesn't require climbing skills.
  9. Martin White
    Martin White
    1,102
    Mar 31, 2006
    Abbotsford, B.C.
    Why not temporarily install a step lift? Some of them fold up enough to be out of the way. You could always take them off later....
  10. GeoRoss
    GeoRoss
    1,900
    1,209
    Dec 4, 2004
    Tucson AZ
    That's funny, I had to put the running boards back on last week due to my wife's pregnancy! It was too painful to watch her get in and I didn't want to take the mini-van on a trip up to N. Arizona.
    Ross
