Caster Trouble?
Discussion in '80-Series Tech' started by Dirk Diggler, Jul 1, 2005.
  1. Dirk Diggler
    Dirk Diggler
    174
    Oct 25, 2004
    I installed the Med. Heavy OME lift with the OME caster correction bushings, OME damper and Slee Tie and Relay rods. I also went up to 305/70/16 Bridgestone AT's. After I had the tires installed, the tech told me the caster was perfect, as was the alignment. Unfortunately, at highway speeds (60 mph and faster), the 80 still feels like it is wandering a bit.
    I then rebuilt the front axle and had the caster checked aqain at a different shop. Again, I was told it was perfect.
    Any ideas as to what is causing the wander? It is not bad, but it does not feel right either. Any help or links is appreciated.
  2. cruiserdan
    cruiserdan SupportingVendor Emeritus Moderator
    22,721
    7,576
    Mar 27, 2003
    Land Cruiser Heritage Museum broom closet
    What is "perfect"? Do you have the measurments they took?
  3. Dirk Diggler
    Dirk Diggler
    174
    Oct 25, 2004
    No, but I can get them in a few days. Do you have any numbers as to what is normal caster?
    Thanks for the help.
  4. cruiserdan
    22,721
    7,576
    Mar 27, 2003
    Specification is 3 degrees +/- 1 degree (2-4) range.
  5. Kalawang
    Kalawang
    1,099
    3
    Jan 25, 2005
    Philippines
    If you have a wander, check your tie rod ends and steering damper.
    Kalawang
  6. Darwood
    Darwood
    1,957
    9
    Oct 8, 2003
    Z.O.W.I.E. Headquarters
    Also when you get the measurements post the toe measurement. Too much toe out can make things squirrely.
  7. Dirk Diggler
    Dirk Diggler
    174
    Oct 25, 2004
    Thanks for the help. I am taking it to a frame and alignment shop on Thurs. A mechanic friend strongly recommened this new place. I will post the numbers after that happens.
  8. photogod
    photogod
    1,579
    8
    May 21, 2004
    MN physically, MI spiritually
    I did my lift and had the same problem. Got new tires and problem solved. The old treds were unevenly worn and caused a pulling. It tracks perfectly straight now.
