caster plate welding question
North Cadillac
I know I could call slee in the morning, but I have decided to go ahead and weld the castor plates. Will it generate enough heat that I should remove the arms so as not to melt the bushings?
lx450landcruiser
Moderator
Uganda
from the pics those plates look fairly thick i would say you would want to remove them as its not to much more work. it might not melt them but i would think it would if your looking to get good penetration on the welds.
mike
sleeoffroad
Supporting Vendor
No, if you only weld the front seams of the plates to the front of the factory brackets you will be fine.
e9999
You want to do what...?
Moderator
US
and these in principle could then be removed with minor grinding of the weld?
Rockville, MD
Look at that Alex, you don't even need to call Slee in the morning. He comes to you in the evening :D Occasionally I question the almost obsessive following Christo has, and then I realize the reasons behind it. :cheers: Christo :)
North Cadillac
Part of the reason i'll keep feeding his dogs. Thanks Christo. :cheers:
