I read a layman's explanation somewhere, but I'll be darned if I can find it now.
What is the physical reason that an out-of-spec caster front axle will snap the wheels to one side when trying to flat-tow?
I understand the concept of "trail", the distance between where a vertical line thru the axle touches the ground, and a line thru the steering knuckle centerline touches the ground. When you add extended shackles with no caster shims, this distance decreases, but I can't physically picture how this encourages the front wheels to want to track to the side.
