Caster adjustment on HZJ77
NYS
I’m trying to figure out how to adjust caster on my hzj77. I don’t see any way to adjust, am I missing something ? Any insights would be appreciated. Thanks. Gratuitous image attached
They make degree correction shims that fit between the springs and axle perches
Thank you, do you happen to know manufactures them or where I might locate ? Know that I know, I’ll start searching. Thanks again
Like these?
I have lifted 50mm in front inadvertently with hd springs, usually does not require castor adjustment for 50mm, but sometimes I wonder if it would be better. for the diff..
just whilst more research..
Perfect. Right here in the good ole USA. Thanks
Caster shims or caster correction trunnion bearings are the easiest option, cut/turn on the axle housing is another option.
Do y'all sell these components out there?
