IdahoDoug said:Tarbe,
I think what Cary means is not that the synth will shed heat any faster, it's that its behavior as a lubricant at that temp is better. Mineral oil will undergo a permanent chemical change similar to 'burning' (which it's not doing only due to the lack of oxygen) that will cause deposits in a process known as "coking" that can block small passages, etc. Under the same conditions, synthetic oil will not behave like that, but will continue to behave like a lubricant. He's saying that the synth has the capacity to do this at temps from 100 to 200 degrees more than a mineral oil.
This is one of the chief reasons I prefer synthetic since I tow heavy and it is exactly these hot spots in the engine (that are not reflected in the temp guages) that I want my lube to handle.
DougM
I understand, Doug. I am trying to keep the discussion technically correct. Forgive me - as an old Chemist, I see "heat capacity" and that means something that is completely outside this discussion.
