Carbon Metallic front brake pads work awesome.
I've put about 15K miles on my LX450 since I bought it at 80K, and the last 10K have been with Performance Friction Carbon Metallic 502Z 0502.10 front pads. I don't know what kind of pads the PO had on the truck, probably whatever was cheapest.
All I can say is the Carbon Metallics work about 100% better than whatever was on before. No BS: fron 65 MPH I seriously feel like I'm stopping in half the distance, without any fade at all, ever. Upgrading the pads was the only change, didn't turn the rotors or anything. I did attempt a proper brake-in after the install: going from 50 MPH to 10 MPH, a minute to cool, then repeating about ten times before putting the truck away for the night.
All I can say is they were the best $65 I ever spent on a vehicle, and I have no affiliation with PF.
NAPA has an agressive rear pad that looks like a good match for the CM fronts, though I don't have the part number handy and haven't tried them yet.
Hay 1000-oaks, looking fro a good brake person in the area(ventura county) or did you do the work yourself?
Thanks, Cliff
I'm curious to see how your rotors hold up. I'm pretty happy with stocker pads, and I don't enjoy replacing rotors, but if the pads are that much better . . .
1000-oaks said:
I've put about 15K miles on my LX450 since I bought it at 80K, and the last 10K have been with Carbon Metallic 502Z 0502.10 front pads. I don't know what kind of pads the PO had on the truck, probably whatever was cheapest.
All I can say is they were the best $65 I ever spent on a vehicle, and I have no affiliation with CM.
Curious how they are in the rain...
For a Ventura county shop, look into Camarillo Independent.
He resurfaced my Drilled and slotted rotors and replaced the pads that I brought in. He also warned me of the blueing on my front rotors, but turned 'em anyway. I've been there twice with parts I've bought off the net, clean shop, huge TV and couch to sit in while you wait. Next to Tony Roma's, you can see it from the 101.
1000 oaks sorry for the semi post hijack, cruiserman thanks for the confidence builder but need mo' tools and to move all that "important" stuff the wife keeps in the garage before I would attempt this. Pablo thanks for the tip I'll give him call. From your sig line description of your cruiser think I saw you at the post office next to Buena High about a month or so ago if so sweet rig!!!!!!!
Thanks again, Cliff
Nothing is easier to change pads on than a Toyota.
Pull off the wheel, look on the back side of the caliper, carefully remove the wire clip that goes through the pad retention pins (pop out the center first, then flex it to pull it out of the pins, if you break it you gotta get a new one before you drive the truck), slide out the pins, grab the ears on ONE pad with two pair of pliers or channel locks, pull it out of the caliper (don't pull out the other one yet), use two big channel locks at once to simultaneously press both pistons all the way into the caliper, smear a little anti-squeal goo on the back of the new pad, slide in the new pad, then do the other pad the same way, reinstall the wire clip, then the wheel, and you're done with that side.
That easy, almost don't even need tools. Most new pads will come with anti-rattle/cooling shims, use 'em. If they don't you may have to use the shims off the old pads.
They're fine, why would they be any different? Because they "bite" better? Just don't push on the pedal as hard!
lol...couldn't resist.
1000 Oaks - According to that part#, that should be the PF Z-rated compound pad for the 80 series. Where did you find these??? I've been wanting to try this compound, since it should be ideal for these heavy rigs.
FWIW - I'm having 100 series pads quoted in this z-rated material to use on my 80 series. PF doesn't list the part, but Porterfield-Brakes will make any pad with any compound they carry. Just waiting to see how expensive it is.
edited: Remembered that 100 series pads fit in front calipers only.
Just looked closer at the PF pad application guide, and they show the same front pad for Toyota Landcruider (91-00) and LX 450/470 (96-00). It's listed as the 0502.XX that 1000 Oaks bought. The last two digits designate the compound. If that's the case, then this may already be equivalent in size/thickness to the 100 series pad. I may only need the rear pads custom quoted in the z-rated compound if 1K Oaks can help provide a vendor for the fronts.
I've also seen places like Autozone and others list the 0812.XX for the 100 series, which is the Tundra (and possibly Sequoia?) front pad. Anyone know if these are much different in size/shape/thickness?
Bruneti said:
FWIW - I'm having 100 series pads quoted (front & rear)
Since you are considering aftermarket pads this may not apply but you should be aware that OEM 100 series rear pads will not fit in the 80 series.
I would also be a little skeptical of fitment since they are saying one pad fits the early 80s (91-92), all FZJ80s, and early 100s. Each of these is a different size OEM pad.
-B-
I had a set of harder ("sport") metallic pads on another vehicle a few years ago. They worked superbly in dry but were scary in rain/slush. Once the pads heated up/swiped the water from the rotor they worked OK...but the first hundred feet at highway speeds was disconcerting. Never had that issue with stock type pads.
In SoCa it never rains so you wouldn't know about that ;)
Beo - Thanks for the reminder about 100 series fitting front only. I edited my post and my request. Good point also about the early (FJ) 80 series vs. FZJ front pad. I may propose to them that I get a traced outline of the proper 100 series front pads and 80 series rear pads with thickness measurements. Surely someone on here has a set of pads waiting to go in that could help with this. Worst case, I could run down to the local Toyota Dealer.
The front brake pads for Tundra are the same as those for Sequoia and LC100. They all fit the 80LC front just fine.
I'll have to check, I bought them online and don't remember the place. They were about $65 for all four pads, if memory serves.
The cold-rotor bite is great, no issue at all.
Bruneti,
Somewhere in the bowels of the archives there is a picture of the various front 80 series pads (91-92, 93+) along with a set from the 100 series. Don't hold me to it but I think it was posted by Landpimp. Try an Advanced Search in the 80 section with Author=Landpimp and keywords "grind + pad". As I recall, he was showing why a stock 100 series pad had to be ground down to fit an early 80 series. Also try "Axxis" and/or "metalmaster" as those keywords may get you closer to the post with the pics. The pads he tried were from that vendor.
-B-
