Carberator Gasket?
Discussion in '60-Series Wagons' started by BigGun J, Aug 13, 2006.
  1. BigGun J
    BigGun J
    108
    1
    Nov 30, 2005
    Seattle WA
    There is a heat insolator under the carberator. My carberator rebuild kit came with two gaskets. They are not cut to seperate the primary and secondary chambers. The lower gasket between the manifold and the plate would be fine. My question is, between the card and the plate I should have a gasket with two holes to seperate the chambers? The old gaskets had two holes.
    Correct??
    Thanks, Jim
    1985 FJ60 still on blocks in the garage. I think she hates me.
  2. NocalFJ60
    NocalFJ60
    3,550
    Media:
    6
    Albums:
    1
    6
    Aug 2, 2004
    San Francisco Bay Area
    I read on here awhile back not to use any gaskets. I didn't use any when I put my carb back on it and it worked fine. Make sure the manifold is clean where it mates and use just the insulator. It has kinda of a rubber matterial on both side. If it is in bad shape then replace the insulator.
  3. VETTE60
    VETTE60
    1,419
    Media:
    12
    Albums:
    2
    48
    Oct 10, 2004
    Pollock Pines,CA
    just use form-a-gasket.
  4. BigGun J
    BigGun J
    108
    1
    Nov 30, 2005
    Seattle WA
    Looking at the bottom of the carberator and I would say that I need the gasket cut to have the two holes. There is a vacuum port hole and I beleave it would need to be sealed from both bores as the bores should be sealed from each other?
    My insolator bases are not the best so I thing I should use the gaskets. I just cut me a new one to match the old two hole gasket.
    Thanks for the suggestions. Jim
  5. Cruzerman
    Cruzerman
    2,085
    438
    Apr 23, 2005
    Oregon
  6. BigGun J
    BigGun J
    108
    1
    Nov 30, 2005
    Seattle WA
    CRUZERMAN!
    Thanks, I booked marked that site. Hopefully I am getting closer to being able to start driving her! Then of course all the other differed maintenance items that are on the list will come into play. Thats the beauty of owning an older rig. Someones tired old gal is another mans honeymoon.
    Thanks for the link. Jim
  7. NocalFJ60
    NocalFJ60
    3,550
    Media:
    6
    Albums:
    1
    6
    Aug 2, 2004
  8. Cruzerman
    Cruzerman
    2,085
    438
    Apr 23, 2005
    Oregon
    Thanks for the link NocalFJ60. Looks like I stand corrected (yet again).
