I just rebuilt my stock Carb this weekend and there is one spot I can’t find an answer to.....
I need to figure out the clearance between the little lever on the slow cut valve and the linkage arm that pushes down on it. Mine doesn't look like it’s making contact even at WOT. In the pic above, the red arrow is pointing to the slow cut valve.
Overall, my carb rebuild was a success, except for a weird flat spot in acceleration at full throttle. If I slightly back off the gas pedal, the secondary kicks in. Wasn’t sure if this issue correlated with the slow cut valve not being actuated?? It is also a little herky-jerky when the secondary initially opens.
Here are some photos of the freshly rebuilt carb. I was a little intimidated at first by tackling the rebuild, but it was way more simple than expected.
