Carb question
My carb is a '74 so I may not know what I'm talking about, but low on the secondary, below the throttle plate is a second, counterweighted throttle that may be frozen. Your linkage should open the secondary, but the counterweighted one will not open until you have enough air flowing, ie, higher rpm's.
With the motor off, manually work the linkage and see if the secondary is being opened by the linkage, then also check the counterweighted plate below it. You can definitely feel it when my 2* kicks in.
.02
Ed :)
yeah, check that linkage out.
i've been playin round with a couple carbs and they're all stuck.
malphrus
they don't kick in untill around 40mph, in 3rd at around 40.....PUNCH It......you sould feel it kick in. Also pop the air cleaner off, if the 2nd barrell is clean.......it aint working. Prolly what is wrong is the diapharm for the secondairy is torn. on a 82 its vacumme operated
hmmm yours is canadian so its prolly not vacumme operated.....
