Carb mixture screw
  • Thread starter Lordhelemt
  • Start date
  • Watchers 2
L
Lordhelemt
Arlington, VA
Looking to adjust the carb but i'm not sure where the mixture screw is located. Is this the location (see pic recessed circle). If so how do I remove the cap, it sits flush with the carb body. Drill it and pull with a sheet metal screw?
IMG 17431
OSS
OSS
Oblivion
The idle mixture screw is capped for a reason. To prevent tampering.
But if you want to mess with it - instructions are in the 2F Toyota manual
  • 2F Engine Idle Mixture 2.pdf
Spike Strip
Spike Strip
Let's Go Brandon !
Kalifailure
It's VERY easy to over-drill and damage the mix screw slot, making it difficult to adjust (the screwdriver slips).
Use a punch on the cap and a stop on the drill bit, if you can.
