I've got an F('74) carb mounted on a 2f manifold, so I can run the 2F aircleaner, because I needed room for the PS pump. The 2f manifold is shaped a little different than the F and the carb is shorter than a 2F carb. I'd like to use a heatshield/carb spacer from a 2F, to keep as much heat from the header away from the carb, but that does not have a place for the PCV to vent into. Can I use both spacers and get the height I need. Looks like longer studs will be necessary, but NBD. I assume if I get everything tight and sealed there should be no problem.
Hey, does the pcv vent into the aircleaner on a 2F????
Thanks,
Ed
Thanks,
Ed
