• PLEASE READ >>> Accounts Security Locked
    The link above goes to a thread in the Announcements - Help - Testing section of the forum....you are welcome to follow normal menu structure and find it there. ~woody
Carb ID off a 69
San Diego, CA
So I rebuilt this carb after having my recently purchased 69 cruiser redline uncontrollably on me last week. I was able to get it to calm down to 2100 rpms after wiggling the linkages (I think the secondary was stuck open).
Anyway, after rebuilding the carb and idle shutoff valve (which was rusted open), I realized the FSM shows parts of mine as a 2 barrel F and parts as a 2F. Can anyone help ID it?
The number on the body is 9G31 and the spacer seems like it's off a 3/69-9/69 2 barrel F.
( while taking pictures I saw where the hose on the Idle solenoid was suppose to go)
I appreciate any help the carb gurus can give!
Bryan
San Diego, CA
I guess my main question/ concern is that the mechanical linkage for the secondary butterfly doesn't get fully actuated with the primary valve opening. The secondary has the diaphragm that uses the venturi vacuum to actuate which the FSM says is how a 2F carb works. Do I have a frankencarb or did my carb get manufactured this way? My FJ has a birthday of September 1969.
Any help is appreciated!
Pennsylvania 18350
It is my understanding that the carb date stamp would indicate it was manufactured on July 31, 1969, making it the 3/69-9/69 carb you mentioned. I too, had the same carb on my 7/69, but was steered away from a rebuid of it by Mark Algazy of Mark's off-road, to a later carb because of reliability issues. You may want to CALL him with your questions. Good luck!:steer:
Tucson
That carb was the transition from the single barrel on the early 69's (which I had). As recommended, I would go with a later version.
