Hello all. Newly registered but have been reading here for a while. After looking for almost a year, finally picked up my first 40. It has a 350 conversion, 350 3spd auto trans, with a Holly carburetor.
I did not do the conversion and I know noting about carburetors (besides what I have been reading lately). I actually work for a fuel injection company and have never owned a vehicle with a carb.
The rig has run decent since I got it. I know buying a 40 that I did not build myself would take some going over. Spent two days going over everything. Replaced some gaskets, changed plugs, checked compression etc..
In the past couple days it has started dying on me when in gear or neutral. In park it idles OK.
There is a fuel pressure gauge before the carb and it is reading 12 psi while in park. Jumps around crazy from 10-15 psi while in gear. From what I have read fuel pressure on carb motors should be 6-8 psi and steady. I am assuming that the fuel pressure gauge I have is correct, so my 10+ psi is way too high and probably causing my issues. At least that is a place to start.
Since i am used to MPFI I feel out of my element here. There is no fuel pressure regulator on a carb system correct? I do not have an adjustable fuel pressure regulator. Should I look at replacing the pump or getting a fuel pressure regulator? Does the mechanical pump use any vacuum? I did not see a vacuum line on the pump.
Any input?
Any input?
