CARB FAN IS ALIVE AGAIN!!! E-Z fix!
Discussion in '60-Series Wagons' started by ssgoods, Feb 27, 2007.
  1. ssgoods
    ssgoods
    318
    Dec 14, 2006
    Tahlequah OK
    I have been having probs with my carb fan, so I decided to try and fix it. Here are the steps!
    Unplug and unbolt it, take out the screws for the blower motor, get a can of electronic cleaner spray. On the bottom of the fan, there is a clear tube, take it off. Turn the entire assembly upside down. Spray the electronic cleaner into the hole where the tube was. While spraying it, turn the fan by hand, both ways. Periodically drain the excess spray by gently prying the inner gasket on the lip of the blower motor base. I found this out by it leaking anyhow, and what comes out is some extremely nasty stuff. Continue spraying and draining for 5 mins or so. Make sure that you use fast drying spray, and that you let it completely dry before plugging it back in. P.S. the bolt inside of the hood helper springs can be hard to get back on, so you might as well take the assist spring mount off in the beginning.
    The end result in my case is great. I can't even hear the motor running, just the air being sucked and pushed into the engine bay. Let me know how this works for you all!
    -Nick
  2. Pathfinder
    Pathfinder I am the STIG
    1,382
    3
    Aug 8, 2006
    Palm Harbor, FL
    Is your fan hooked up to the manifold thermostat or is it just grounded. This is a fix that I have been wanting/'needing to do. My wire looks like it has been burt off.
    Where did you get the electric cleaner? Could you use brake cleaner? That is a fast drying cleaner.
    Thanks This has been on my mind for a couple of weeks now.
  3. ssgoods
    ssgoods
    318
    Dec 14, 2006
    Tahlequah OK
    Mine is still hooked up to the thermostat. I got the electronic cleaner at autozone. It is made for terminals and plugs. I would definitely stick to it because it is made for electronics, rather than use the brake cleaner.
    The stuff at Autozone is some of the best because it doesn't leave any residue, I've been using it for years on guitars and amps. I also unplugged most everything under the hood, seperately of course, and sprayed them clean. The carb fan really does work good now though, it was quite noisy when it worked off and on before.
    I imagine that this would help with the heater blowers just as well.
  4. Pathfinder
    1,382
    3
    Aug 8, 2006
    Palm Harbor, FL
    I will give it a whirl and let you know how it comes out. Thanks
  5. 84yota4x4
    84yota4x4
    361
    24
    Oct 18, 2006
    Chattaboogie
    Thanks for the advise, I'll be trying that soon as well.
  6. FLA60
    FLA60
    79
    Mar 15, 2005
    Winter Springs, FL
    I've had mine disconnected for a year with no issues. I disconnected it because it always seemed to be on. I've thought of it somewhat akin to the appendix, not really needed.:grinpimp:
  7. ssgoods
    ssgoods
    318
    Dec 14, 2006
    Tahlequah OK
    I have noticed that mine starts the same in the winter, rather the fan is on or not. In the summer, however it seems to make a rather large difference when warm starting.
  8. Pathfinder
    1,382
    3
    Aug 8, 2006
    Palm Harbor, FL
    Mine is not working and on Hot starts I really have to let the engine turn over alot till it decides to fire up. I think this is due to the gas boiling off in the carb. Also I have noticed that the engine once turned on after a running at opperating temp is pretty high on the temp guage till it has been started and given a chance to run a few minutes.
    I want to get mine working.
  9. ssgoods
    ssgoods
    318
    Dec 14, 2006
    Tahlequah OK
    You can also check it out of the car by taking it out and hooking it up to a 12 volt source, either your battery, or a portable jump starter. Just 1 wire to the red, and 1 wire to the black. That way, you can see if it is just your thermostat wire. If would probably be a good idea to clean it anyways, though.
  10. BigGun J
    BigGun J
    108
    1
    Nov 30, 2005
    Seattle WA
    Good suggestion, But I would suggest pulling the motor back out. Pull the stator out of the housing. There are felt swabs that need to be oiled to lube the bushings "non bearing motor". You cleaned all the brush and dust out and now you have continunity again. But the cleaner will dry out the felt pads and now you do not have any lubrication. If your brushes are worn down below about a 1/4 of an inch. Take one to a local hardware store and look in there bin and pick two that are as close to the outer diamiter. Cut lenth to about 3/4 of a inch. Light emmory the contact surface on the rotor, about 20 drops of 20 W oil on the pads. Reassembly and you are good to go fo good number of years.
    Jim
  11. CruisinFJ60
    CruisinFJ60
    6,158
    Media:
    219
    Albums:
    8
    35
    Oct 19, 2006
    Ft. Worthless, TEXAS!
    i should get mine working again just cause its cool to have. reguardless of if it cools the carb or not. its a conversation peice.
