In the process of doing the little things, I decided to take this apart and see what it looks like. It failed years ago while I was someplace I could not get even small parts readily. I just put the fan on a toggle switch and run it manually as needed. I keep the box in place and plugged in, tho, since I "re-import" the Blue Mule every 4-5 years, and the customs inspectors always look at these things.
I'm guessing that the ummm... lava flow on that component (condensor? the little can) is not normal? If that is what failed, would it be possible to replace that bit and have the relay functional again? Just curious...
