Carb choices
Discussion in '60-Series Wagons' started by BillNoy, Feb 24, 2007.
  1. BillNoy
    BillNoy
    71
    Jan 28, 2007
    Beaverton, Oregon
    I found an 86 FJ60 that was all that the po said and more and I'll be picking it up Monday:grinpimp: .Cool. It has a Weber carb on it instead of the original. That was the only real mod made to the truck.I remember reading on posts that there are 2 sizes of these carbs available( or more?) . On the whole ,do the Webers do the job performance/economy wise or should I start shopping for a stock carb? The po says he never checked his milege so I'm just curious?
    Thanks
  2. John McVicker
    John McVicker SILVER Star
    2,252
    553
    Jul 11, 2005
    Big Pine, CA
    Most generally agree that the best carb choice for a 2f is a good operating oem. Thats not to say you can't be happy w/your Weber. However overall the Weber can be finicky to adjust/keep adjusted.
    I ran a Rochester on my 2f for 20+ years & was very pleased w/everything except mpg. I switched to a Jim C. rebuild oem & experienced no loss in power AND mpg increase from hiway 9-11 to 13-16 depending on my foot. No matter how I babied the Rochester I NEVER got more than 10-11 mpg. Often much worse. I expect you would experience similar results with a good working oem carb. I will add that I also switched from a Delco to an oem dizzy at the same time.
    Plenty in 'Search' on Jim C. as well as your subject.
    Good luck
  3. BillNoy
    BillNoy
    71
    Jan 28, 2007
    Beaverton, Oregon
    So the original is a Rochester? I assumed it was Toyota?
    Bill
  4. John McVicker
    2,252
    553
    Jul 11, 2005
    Big Pine, CA
    No, the original is not a Rochester. Sorry if I was unclear. I was just giving an example that other than oem (your Weber) can run good but overall most including me, would steer you to a good rebuilt (Jim C. & others) oem carb. As good or better performance & almost always better mpg.
    Thanks, John
  5. cando john
    cando john
    134
    Sep 14, 2006
    philadelphia
    I Ran The Rochester For A Couple Of Years Was Getting 11-15 Mpg Simi-desmoged" Gutted Air Pump " Egr Was Still In Play" Dui Dizzy And Thats With A 33" Tire And 4in. Lift ..........now I'm Running A 2bbl Holly Out Of A 87 Dodge Ram That Came With A 318cid .... I Like The Way It Pulls ....works Very Well Offroad.... Still Desmoged But Now There Is No Cat / Gutted Air Pump/ No Egr Every Thing Else Is Still Under The Hood Dui Dizzy Still Run The 33" Tires Not Watchen Mpg @this Time But Will Post Later...............john
  6. roscoFJ73
    roscoFJ73
    15,209
    Media:
    3
    Albums:
    1
    1,482
    Jul 22, 2003
    Perth Western Australia
    The original is an Aisan carb. Same company that makes the gearbox,brake discs and a hell of a lot other parts on a cruiser.
    Folklore has it that a member of the Toyoda family owns it;)
    Oh and I also think the original is the best if tuned right.
