I have two issues I have been dealing with the last two weekends that I have not been able to figure out.
1. I have a F engine out of a 71 FJ40. It starts and runs but smokes the garage out and will not run without the choke being fully open. If I turn the choke off it sputters and dies. The engine sat for about six months and am curious if it is due for a carb rebuild. I have not yet checked the points but engine ran fine when pulled out of it's original 40. The smoke appears to be white...
2. I am having trouble getting the brakes bled and am curious if there are any tricks.. It has a brand new master cylinder and I can get the air out of the front brake lines but not the rear... Any suggestions...?
3. I am 95% done with a complete resto and haven't cut any corners as of yet and want to rebuild the carb whether it needs it or not (Piece of Mind mixed with OCD). I looked at the carb but couldn't find any numbers on it.. Where are they located? The only things I found was "Assam" or "Arron" I couldnt really make out what it said. Does anyone know what carb this would be. I believe it to be a factory but want to make sure before ordering the rebuild kit.... Any help is appreciated...
