Car Wash = Buckin Motor
North Front Range, CO
Power washed the motor yesterday (after I went up the steep hill) and when I drove off the motor was bucking the whole vehicle.
It would buck real bad when I gave it the gas but would go away when I let off.
I drove 5 mi and it cleared up.
I had this happen before and changed the plug wires. After that I could wash the motor with no problems.
My wires are 3 yrs old and have 55,000 mi on them.
I assume that one of the spark plug tubes is filling up with water and shorting out that cylinder.
If that is what it is, one of the spark plug boot covers must not be sealing very well.
Is it a bad idea to use a little sealant on the boot cover?
If the sparkplug tube did fill up with water, would all the water boil off past the spark plug boot?
That is, maybe there is nothing wrong with the boot but the high pressure from the washer forced the water past the boot. Will ALL of the water boil off or do I need to remove the spark plug wires when the motor is hot so any moister will dissipate?
I sealed mine. I also use dielectric grease in the plug wire ends.
I found that a realitivly shallow water crossing will cause the fan to throw water all over the engine compartment shorting out wires. (see pic on 'mud homepage:o )
My guess is that the water will boil off and eventually the plug will un-foul, but you might have to pull the plug to clean it.
I know on Chevy HEI motors they say to use dielectric grease on the plug wires.
Why doesn't it say to use dielectric grease on Toyota motors plug wires?
Do you use dielectric grease on the wire ends that go on the cap too?
Kurt--
I've gotten into the habit of using dielectric on most of my electrical ends and areas--battery terminals, splugs, wires, etc.
This seems to be cheap insurance against water damage and the like.
Your junk'll eventually dry out and you'll be fine...
Cheers.
-onur
Akron, OH
Wet distributor.
Yup, and on pretty much all of the electrical connectors
Me too!
Apply the dielectric grease not only to the top, where the seal with the tubes occurs, but at the bottom where the boot fits over the porcelin. This will prevent the rubber from sticking to the plug and makes removal much easier.
You can use an infrared temp gun like the RayTek to tell which plug is shorted - it is very quick if you have thrown away those crack-prone sheet metal exhaust manifold covers. The cylinder with the "cold" manifold pipe has the shorted plug.
John Davies
Those crack prone sheet metal exhaust manifold heat shields help extend the life of other engine components, such as the crack prone not so flexible synthetic rubber air intake tube.
I'll second Dan's post. I have washed the engine a few times and on one occation I opened up the dist. and it was rather damp. The cap doesn't seal too well as is. If you can get it running it's rough and cross firefor several minutes.
Seems like when I had this problem, someone suggested sealing or reducing the size of the hole in the dist. cap. Any neg. repercussions of doing either that anyone knows of?
The vent is there for a purpose. If you live in an area with high humidity you may experience moisture due to condensation. I believe someone posted a dizzy mod that involved a breather tube of some kind.
-B-
The holes that I have problems with are in the bottom alloy part of the dizzy. The plan is to seal them with epoxy, tap one for a fitting and run a breather line to under the dash.
I had the same problem when I washed the engine of the 94 I used to have. I took extra care to seal off the dizzy and keep water away from it.
Turned out to be water in the plug wires -- the engine was running on 4 cylinders in my case.
Dielectric grease is your friend :)
Pluggin the holesin the distribuitor is a BAD idea. Those holes are there for a reason. And it's to let moisture out. If you plug them, the distribuitor won't be able to breathe.
What I've seen guys do is to presurise their distributors. They do this by running a air hose into the dist cap, like a ARB line. When going over water, they apply 5psi to the dist. The positive pressure is enough to keep the water out.
Regards
Alvaro
I have read that the dist neds to breath before. On the 40 and toy pick ups I have completely sealed them and had no problems for many years. Am i just lucky or do they really need to breath?
Thanks
Chris
When I did my head gasket, I epoxied small metal tubes into the two distributor holes and ran rubber tubing a short distance downward. The air can still circulate, but there is no way for splash water from an engine wash to get inside.
John Davies
Regards
Alvaro
I've heard of this too. But rather than going to this much trouble, wouldn't it be possible to fashion some type of breather tube that connects to the hole?
EDIT: Nevermind...I just read John's post. Sounds like a breather is possible.
I think the fj60 had two holes in the dist cap.
One was hooked to a vacuum.
The other was to the air cleaner.
When I converted the dist tp HEI, I drilled a couple of holes in the cap and sealed the chevy dist best I could. The chevy dist is not water proof, big gap between the cap and dist.
I see no reason one couldn't some how hook up a vacuum line and line to the air cleaner like the 60 has.
The only hard part would finding a vacuum line to hook up to it that wouldn't cause a vacuum leak.
You would want to make sure the vacuum line you choose doesn't have gas fumes when the engine is hot soaking.
Seen a few dizzy caps explode from a leaking advance diaphram.
My 78 40 had a line from the dizzy cap to a check valve mounted on the inside of the firewall
