Well ...I thought lessons learned and knowledge gained might be shared here on this thread. Towing related ...
Well as part of my self-assigned work projects that I want to accomplish while I"m off from work. (change the trailer ball coupler on my trailer). I have an approx 20ft metal deck car hauler trailer with an adjustable mount for the ball coupler which allows you to adjust the height at the tailer ball (which you might do depending on your vehicle's bumper height), as my trailer is a bumper pull.
I changed the coupler mainly because the old one was nearly impossible to verify that the ball coupler had locked down on the trailer ball and I got tired of that. The old coupler looks like this but I don't see any brand marking on the one I have. I'll keep it for a spare. http://www.etrailer.com/Trailer-Coupler/Pro-Series/PSA256S0303.html
So...I swap out the 14K ball coupler for a new one from bulldog thats rated at 15K. This is a new model from bulldog as their previous models were about 10K rated as I recall. The adjustable trailer hitch uses a combination of two "C Channels" one made into the trailer (you can see these on places like etrailer.com), and the other half made into the ball coupler. Both have a series of holes pre-drilled into the side of the c channel and that's how you adjust your height. The critical point is that the ball coupler mates with the trailer with only two 5/8th size bolts, roughly 4.75 to 5 inches long depending on what fastener and washer combination you use.
http://www.etrailer.com/Trailer-Coupler/Bulldog/BD028657.html
http://www.etrailer.com/Accessories-and-Parts/Bulldog/BDAC3000300.html
The new and old ball coupler had grade 5 hardware which I don't care for and so I replaced with grade 8. Did a little research (some may know this already), but you have a choice of lock washers, nylon lock nut, stover lock nut. Obviously you don't want either of these bolts to come loose, since you only have two. The grade c stover nut is the preferred fastener to use from what I read and from a few people I talked with. Normally I don't cocern myself a great deal with hardware other than I generally use grade 8 all the time regardless. Stover nuts are not suppose to come loose...so just sharing that.
The other thing I found out today is that my unloaded trailer weighs 3K. I previously assumed something around 2.5...scales said 3k.
I also found out previously that the lift jack on the trailer would actually auto rotate down from the wind as I drove down the highway and I had to rig up a little safety chain to just hold a pin in the shaft of the foot which keeps if from free-wheeling downward. I would have never thought this could happen, but the foot on my trailer jack free-wheeled to almost touching the ground on more than one occasion and I double checked the trailer both time to exclude the dumb (a$$) factor. The wind force would move the trailer jack handle around enough to cycle it over and over and the jack foot freewheeled downward. Had to experience it to believe it.
I also found out that my nice 20 ton bottle jack (brand new) did not work when I had a flat on the trailer a few months ago coming home from windrock...boy I was mad when that happened.. Got a new jack...but I'm going to get one of these too...its called a trailer aid and is invaluable on a light loaded dual axle trailer...light = less than 15K
http://www.amazon.com/Trailer-Tandem-Tire-Changing-Ramp/dp/B000I4JPZE/?tag=ihco-20
I've seen similar items made out of 4*4 or I saw one on amazon made out of metal too.
I've used a home made one out of 4*4 to change tires on a army 2.5 ton truck so they do work and save you a lot of time. If you have two flats on the same side of the trailer though..this tool does not help you...hopefully you will only have one at the time.
My little experience with the non-working jack cost me about 5 hours of down time and very aggravating. As I related in a another post...a guy stopped to help me who best could be described as "challenged"... he had a small toyota late 80's era pickup and had the old factory bottle jack and tool in the bed. He let me borrow that and would not let me give him any money. I did all the work and he watched...in the end the old toyota bottle jack lifted my loaded trailer enough to get the bad tire off and the spare on, but I thought surely the jack was going to break more than once...I kept clear in case it would have. There for the last 2 inches of height it was all I could do to get one or two cycles of the jack and then I would have stop for a few min.
Please post up towing related stuff so it might help others.
