1984 BJ42. I rebuilt this 3B probably 10 years ago and finally got around to starting it about a year ago but only ran it for about 20 min. At that time I struggled to get the oil pump to prime, what finally did it was cranking (GPs removed) while a tank of vacuum sucked on one of the oil pressure sending unit ports on the right side of the engine.
Its been a year since it ran AND ITS FINALLY READY TO MOVE UNDER ITS OWN POWER AFTER 13 YEARS! and I'm in the same boat, can't get the pump to prime. Last time I imagine the assembly lube may have helped but this time around I'm sure its washed off.
So here's where I'm at: glow plugs out, fuel off, its cranking very fast on 24V with the new batteries, crankcase is 2 or 3 quarts overfull with rotella T 15w-40. the hose from the vac tank is pulling on one of the pressure sending unit holes and there is a known good mechanical pressure gauge on the other sending unit port. (also tried swapping the two)
I start cranking then throw the valve for the vacuume, the clear vac hose starts sucking oil then I close the valve while still cranking. Not so much as a twitch on the pressure gauge.
Any ideas? This method was something I came up with that worked a year ago but maybe its a bad idea that maybe ruined something?
thanks in advance!!!
-Rob
-Rob
