cant find anywhere near me that has a firestick mount...
Discussion in 'Camping & Outdoor Gear' started by lowtideride, Aug 6, 2005.
  1. lowtideride
    lowtideride
    7,611
    Media:
    12
    Albums:
    1
    83
    Sep 29, 2003
    The Sunshine State
    any good ideas....or ideas how to mount it myself aside from duct tape or super glue..
  2. polarweasel
    polarweasel Where's mah cruzah?
    991
    2
    May 6, 2004
    Vancouver Island, BC
    Any CB mount will do. There's nothing special about a Firestik mount. Go visit Radio Shack if you have to, or any truck stop's radio department...
    If you're really set on Firestik (note the spelling), look up dealers online. Plenty of places to mail-order from.
  3. LandCruiserSteve
    LandCruiserSteve
    1,197
    3
    Apr 20, 2005
    Prescott Valley, AZ
    Like polarweasal said, any Radio Shack or truck stop radio dept.
    It's basically an L-bracket with a mounting hole for a Firestik base. Even though it's not mounted dead center within the recommended 'ground plane' area on the vehicle, I've always had good luck with it on the rear corner, provided the antenna is properly 'tuned' after you install it.
  4. Capt. Jim
    Capt. Jim
    2,215
    3,030
    May 1, 2005
    West Palm Beach, Florida
    Plan on giving your super glue away too??? :grinpimp:
    As mentioned above, truck stops do have a good selection of CB equipment. You could just fab one out of a piece of aluminum angle. There's really nothing special about them. You may need the small platic insulating washers that mount in the hole for the antenna base.
  5. Trunk Monkey
    Trunk Monkey Moderator
    9,038
    1,654
    Apr 27, 2003
    Salt Lake City
    Just go with this mount, take it anywhere you want.
  6. Capt. Jim
    Capt. Jim
    2,215
    3,030
    May 1, 2005
    I like it.
  7. lowtideride
    lowtideride
    7,611
    Media:
    12
    Albums:
    1
    83
    Sep 29, 2003
    The Sunshine State
    whahahaha....
  8. Eric_FJ40
    Eric_FJ40
    422
    3
    Sep 5, 2003
    It's hot here
    Hey Al:
    If you're wanting to mount that antenna to the ARB like mine you will need a stud mount. I would also recommend a spring - springs save antennas from getting broken.
    The stud mount will go into the hole on the mounting tab, the spring will thread onto it and the antenna into the spring. The underside of the stud mount will have a connector for the cable - get a cable with PL-259 connectors on each end and it will be easy.
    Eric
    Oh - remember to tune your antenna before using it so you don't damage the radio!
