Can you swap front seats from any year?
california
I hate power seats, so I'm looking to buy some manual seats but I'm wondering if I need to find 95-97 seats or if I can get some from any year to swap in. I have a 96 LX.
Any year will work
Can you swap front seats from any year?​
Not exactly. I believe 91-92 seatbelt latches are separate from the seat. From what I understand it is not a simple thing to make them work.
I swapped ‘94 herringbone brown all three rows into my ‘97 and never looked back.
My fronts can from a unknown year without seatbelt latches
The 94 latches switched over without issue 😉
I want to go back to power seats. I have a pair of 94 herringbone gray non power. They swap right in.
I switched to them because my original leather were really ruined and I thought I might like reliable recline.
Now that I took out all rear seats, I don't need that ability.
Located in New Mexico.
I'm wondering if your seats are from 93+ and someone removed the belt latches, was there anything indicating one way or the other? Could you post a pic of the material?
When I got them they had been reupholstered, so that won't help 🤷‍♂️
Bummer. I was told there was no easy mounting solution for the belt latches on earlier seats when I was looking at a set for my LX, so I passed on them. I hate the leather seats but can't stop buying 80's, so I was hoping to be proven wrong as I'm sure I'll be shopping for cloth seats again at some point.
I put the front and middle seats from a 91 into my 97.
I made it work but the seat belts and latches were not interchangeable.
If I recall correctly, I swapped the middle row belts from the 91 into the 97 along with the seats.
The front was more complicated. I had to swap the front buckles into the 97 because the 97 seats had the buckles attaches to the seats I removed.
I just drilled some holes through the floor of the 97 and bolted the front buckles from the 91 to the floor of the 97 with good hardware.
Again, if I recall correctly the front belts in the 97 did work with the front buckles from the 91.
There are some issues but if you have access to a donor vehicle for belts and parts than it can be done with a little work.
I did the swap back in 2015, but if I remember correctly there was some monkey business to get the buckles to work with the seat I have. The buckles are attached to the seats I think I had to make a notch in the plastic cover on the seat and bend the arm on the buckles and I believe the buckles set foreword of the OEM position.
43IYjcnFaKN59Sq-D_LmtEl5q0QOUeuEls55ZWWdf4n4RVBoGt1v_kDubazVNPpY3A3cEMSI2EF-aNYSFQtnqK_9Gv2ivDoG1_lY7BQZkZsc7uNqWZ9BB0jGzGVDU6fW6g89QdZfbHJSMgSojXEX9PAguQ3WuJDQpkzB7G8boauiucGrvwZEiXgOt4awO_cScij0PIKsHvbPw67nblY8ne7xqJ5aNms8QIjgW2fPQF7kCsjeGqy0MnSNUQoMjG8CflXaNAQwgcKtS2k0fN9W6kfRYRGN10Uln0Q5l-zCH7p-Edz4rj5N9GIspcilHckJWfORIHUf3_s04FDMnaviucmHN1UB7L4dz86IJsdUYYPCvAdeau74CAnUXcqPD-xYlO4b46PpO0DXUEVoN6InuaLEIIPgdGqYMP6-yS5kEP6cVgY-aE75lVzGLiGhvdKYfl9s2JX6QX45cz2Mn5kQiF-fVTt8n2o62zjjjOCJ_F-OnyHyQCyq6O0cdAHQr1eqEXFiXCizvFEUblgrEYOoTBcHxR8FqIEfAk-SA7nzllGZ1ECcA_qxBoJNwGglucGU7pXGD65A4DzC8cRUE84ElnKfymvFd4sD3hgDL1orMQxx_JPw7w-bEbVgLtjXcN_x9F5jWo8TJdguCND5afiITHyiNgzYg56Kjf3LtD6ILwLc1EOjPJpvyU0YRRJh6WjpfJn2FzpHVWBs2ZmzzZ1sTbBRh4vXxWPE_MSi3OaZrmOgKYWHnyfAhwC7UjKUkbI7jP-N6UW3FtvV-SOf6D9kA0cc5IuNK-qiH7wRBjELH7SmNB1CCwF2RIZzHJVf7nm5cZBWlaoVrNH89rc1Edb3aNcAOnmyUBExpTkQG8U8eDDhU0Zm_4r0P7lwJAaFo1GHHtT9bs80jLg4VPzdBVCsRKe2-odKdAj7BpuA8ZIApwXdpw=w704-h939-s-no
Is this the same as the later models ?
I know there the wrong color, I don't care 😝
The 95-97 belts will work with 91-92 receivers. You just have to find a way to mount the receivers which were secured by the inner rear seat mounting bolt at the floor in the earlier years.
