Can you identify this Transmission?
Lakewood, CO
I'm told this is from a FJ45 down under in Australia.
I'm being told it is a 5-speed transmission, 3speed transfer.
When I pulled out my 3 and 4speed transmissions from each of my 40s and 45s, none of them had 21 spline input shafts....
With the drum e-brake on the x-fer, I'm guessing pre-76-ish?
any ideas????
I maybe wrong but I doubt that is a five speed. First of all if it was a five speed it would not have a drum ebrake. 5 speeds did not show up until around 1985 and they were in the 60 series. Never saw one in a 40 series.
It looks like a early 1972 - 1974, 4 speed by the linkage setup for High & Low range.
PS. Maybe the owner might think it has an overdrive but that looks like its got a PTO, which would make it a great find but still a 4 speed box.
Yeh, not a bad box though, have not seen a PTO on a box for a long time. If you were doing a resto to original and needed a box with a PTO you would pay an arm & a leg for it.
Going to look at a FJ40 tomorrow, has 4 small spots of rust but no engine, otherwise complete - $500. Will be my future resto, at that price I can store it for 5 or 6 years.
definetly a pto on that transfer. will have a look at mine tomorrow and get back to you on the transfer. gearbox has thrown me a little, but yes as others have said if its a 5spd they dont have the drum brake...
Toyota did make a drum brake for the rear of the split transfer case. Not sure what market it was used in. TLC use to sell this as a kit. You would change the rear output shaft and speedo housing to one that would take the drum brake backing plated. Used a brake drum that matched the spline of the split case and the backing plate and drum are the same as the one piece case. I've got a brand new brake drum that was given to me year ago because it didn't match the early three or four speed transfer, the splines are too fine. It turned out to be from a split case. I wouldn't think this was from anything from the FJ4X family since the shift tower is so far forward but I wouldn't be surprized if Toyota maybe tried a early transfer case on a different transmission. Just like they put out a few full time 4WD FJ40 in the early 76 model year but never put them into full production.
John
My mistake that would be the 4X series. It's the later H55F for the 60 series that shifter is back further that is wrong for the 4X series I was thinking of.
Early 5-speed
Toyota did make 5-spds before the 80's. Living in Japan in 77 and 78 I had a friend who bought a brand new '79 model FJ40 with a diesel and a 5 speed. I know it was a 5 speed because I drove it a lot.
P.S.
Actually I don't know what model year it was. He bought it new in the early summer of '78. Never looked underneath to see what kind of e-brake it had.
This setup definately has the PTO on it....no questions there.
Are we for sure this is a 'split' transfercase?
The gearbox really has me thrown for a loop....I can't identify it.
The forward-mounted shift tower is really far forward for an LC....but I'm told by the current owner that it came out of an FJ45 in Australia. Who knows?
Thanks for the help.....I'll wait till I hear back from you guys before taking the plunge on this!
The seller is telling me this is comming out of a FJ45, BUT.......
the transmission came from an older vintage Toyota Dyna medium duty truck.
I'm going to have to do some Googling and see what the Dyna is all about....Guessing a medium-duty box truck of some sort....who knows :)
I don't know what bellhousing and clutch assy will work on a 21 spline input shaft....the seller dosen't have those parts anymore :(
Thanks,
There was a FJ45LV being restored in Guatemala....somewhere here on Mud.
They had an H41 mated up to a 3B.....think its the same trans. Really long on the input shaft.
Not going to work on what I've got planned for my truck.....oh well!
AFAIK the H55 was used in the BJ42's(only certain versions) and I dont think it was ever used in a 45(but I might be wrong) I really thought it was a 81+ only item, but may have been used before that.
here is a pic of my top plate from a BJ42(from AUS) for a 5 speed
not sure if that might help or not
When I installed my H55F, it replaced the H41 in my 8/81 HJ60. That transmisison looks VERY familiar, but if that's a one-piece Xfercase, then it is different and the H41 had a split Xfercase.
And looking inside that H55F is giving me bad flashbacks. W/o having installed the output shaft washer and 36 mm stakenut, the thing was bound up between a forward and reverse gear (!) and we had a bitch of a time trying to figure out WTF was wrong.
Definitely a 1-piece TC. But I bet that tranny IS a 5-speed out of a Toyota Dyna. These are small cab over delivery trucks common in Japan, same vehicle as Daihatsu Delta. I owned one in the late 70's, a van model. They are tough little trucks-- the tranny is probably as tough as a H55. Looks like it bolts right up to the one-piece case. That would be a good thing for someone to start importing for those who might want to slip a 5-speed in their 40 without all the added hassles.
This site says that B engines the same as Land Cruisers were common in Dynas:
http://toyotadyna.tripod.com/id16.htmlwere
With the two pictures it's hard to tell on the tranny, it doesn't look like my H55. As others have said, the shift tower is way forward. It is DEFINITELY a single piece transfer case and it definitely has a PTO though the shift linkage for the PTO looks home made.
A 21 spline input is for a "B" series diesel which would make sense it this was behind a Dyna engine as Dyna's also came with the "B" engine.
In "Landpimp's" picture you can see the tell tale 5th gear shifter sticking out the back of the cover plate (rubber boot and all). I have the same on the H55 in my BJ60 but I don't see it in the tranny pictures.
