Can you I.D. these wire?
Northern California
Website
www.facebook.com
Both my headlight harnesses have what appears to be additionally added wires at the same point as what appears to be the oem plugs.There are three female plugs on both sides where the deadlight attaches, just hanging in the breeze.Why was this done/why are the originals just hanging there? Hopefully you can see them in the photos. Don't know how some of you guys circle and point at things on your pictures(computer not so savy).
The PO might have had relays for extra light plugged in there.
Great info guys, thanks. But notice that there are three OEM female sockets hanging loose and there are three seperate wires coming from the harness inwhich they extended with connectors that attach to the headlights. Relays are a possibility however there haven't been any present.
yeah there seem like 3 extra wires, they must connect somewhere. you need to find out.
Eleblanc-off topic, i searched and read topics on primer pumps tonight(as i tried to use mine today and it erupted like a volcano). I read where you bought a Bosch. Has it held up o'kay? I found some part#'s from Lostmarbles posts on these pumps so i'll start calling around tomorrow for a replacement.
Tapage- i'm just finishing my resto. Haven't put the front clip on yet(fenders,grill,hood,etc,). Thought that now would be the best itme to due to turbo job, but wanted to fire the rig up as it hasn't ran for 1-1/2 years. That way when i shut it off i can due the turbo project and know that i will fire right back up without and hiccups. But since everythings was gone through tank,lines,etc. i knew i would have to prime the fuel system. Thats when i tried to use the primer. Although just for kicks, i cranked it over and she started and just purred even after that long but only would run for maybe 4 or 5 seconds before it would die.
Yes no problem at all yet
might be for after market head lights...i can not remember the brand name but you got a complete wiring harnes that tapped into the exiting one... i seen it of a few JDM units that came in...i am thinking PIAA driving lights...
the bosch primers hold up better than those cheezy plastic toyota ones although mine does leak a little when priming and I don't remember the plastic one doing that.... but that being said it still gets rid of all the air in the system which is the main thing....
cheers
Eric
My guess is additional lighting as well.. extra wires to a relay that governs voltage to the aftermarket lights ie: aftermarkets only come on if headlights are on?
At least I found a setup similar to that on my bj 42 last year when I was pulling a bunch of PO wiring during a debug. My off road lamps are no longer tied to a relay connected to the stock headlamps. Dunno if that is a common thing to do, but I wanted to be able to operate them separately.
Well, this has indeed been a long build. I completely forgot about the F/fender turn signal indicators. I believe that's where these oem plugs at each highlight loom tie into. Sometimes the obvious evades me. Thanks fo rall input.
