Can you be too light? - FIXED!!!!
My Toyota diesel is driving me nuts.
I have a B engine in a Series 2 land rover and I have a surging/jerking in 1 st and 2nd on light throttle. 3 and 4 th not as noticeable but still there.
I have covered all the usual items, new primer pump, new fuel filter, diaghram, rebuilt injectors no change. Had a rebuilt injector pump as a spare installed it - no change.
Removed front drive shaft still there, removed rear shaft still there.
The Land Rover has 4.75 rear ends, I am running 7:00-16 tires at just under 30" high.
The Land Rover weighs 3,500 lbs,
The surging is like a governer surging on a stationary engine.
Can this combination of gears and torque be to light causing the surging?
No surging at idle, no surging at 1/2 thru full throttle. The only thing I can think to do is either increase the spring pressure or decrease the spring pressure on the diaghram.
Any thoughts? Any help would be most appreciated.
Thx Jim Y
Finally fixed.
After trying everything I ended up changing the throttle linkage from the old Land Rover multi-link set-up to a cable and pedal asesmbly from a Toyota p/u with a 4 cyl engine.
It seems that the Toyota diesel motor is very sensitive to the foot pedal dynamics.
A big thank-you to everyone who came thru with any suggestions.
Thx Jim
Thx Jim Y
Finally fixed.
Thx Jim
