seeking info >>>
I have an 89' LJ71 SWB cruiser that has 8" diffs, i am seriously considering gettn & modifying a series 60 9"rear full floater diff - as 60 parts are cheap in NZ plus they're built tough ( not sure if they come in "fullfloat" for that model ? ) and using a front high pinion housing/3rd member in the rear , may have to change out the rear crown wheel & pinion to suit - is this possible ?? (will be running disk brake rear )
Why do i want this , well this SWB i have could well have a tough 13BTT or a 14BTT under the boonet in the coming months and will be doing a lift for 33 x 13.5 tyres and don't want any driveline issues as may be running a splitter between the Engine & H55J box , so need a High pinion housing in the rear , I used to be a jeeper and alot of people were running around with High pinion Dana 60 rear ends , so thats where the idea came from !
