can someone confirm for me...concerning emissions system '76 (1 Viewer)
Bay Area California
can someone confirm that for a '76 the Only Main emissions system components include:
Air Pump
ABV ?
(and then im guessing charcoal canister as well)
IDK if this helps but...
Looks to me like PCV, Evap, Throttle positioner Sys, TCS, EGR Manifold Air Injection system, Power Valve Control system, HAI, Transistorized ignition system, and heat control valve system if I'm reading that right.
computer, Vacuum Switching Valve, speedometer cable counter (there is a proper name)
That page in the manual seems not so precise. Like '76 didn't have an AAP, cat, auto choke, double advance distributor, IIRC.
Yes the ‘3/76 at least had points, no transistorized ignition. I believe ‘78 was the first year for that.
Speed marker.
Check the last column of the table (for the FJ), no circle in those rows.
IDK if this helps but...View attachment 2367015
Does this manual have a print date? When looking up parts it shows 2/76 Canada started it own model number ending with am K verses an A. I have an 10/75 76 model. It's hardly ever been driven and basically like it left the factory with only 4,500 miles. Air pump froze and drive belt remove but it's still there.
Some trivia - in the table above, the MX model is the Corona Mark II with the 4M 6-cylinder engine.
I don't know in which month, or whether just CA or Federal too, but 76's had semi-transistorized ignition (ignitor controlled by points). It was a pretty good system. Point lasted forever and it could be wired either semi-electronic or full-on points.
Am I reading it wrong, or doesn't it indicate that those things were not included given there is no dot under the FJ column?
That's awesome. Mine was in similar state with Air Pump in place but no belt and it had seized up. All other smog stuff still in tact.
My 2/76 CA spec. Doesn't have an EGR maintenance interval detector and the corresponding EGR maintenance warning light. I think federal spec. rigs have them.
My 40 also has the semi-electronic ignition referred to by @spotcruiser.
My rig:
EGR maintenance interval detector on passenger side firewall:
EGR maintenance warning light:
Just another reason to buy a '75 and older in California! No SMOG checks.
Hybrid points system, pointless magnetic pickup in my ‘78.
My Feb. 76 CA truck had the semi-electronic ignition and did not have an EGR light. It did have the maintenance interval detector (speed marker) and the two speedo cables though. And it most definitely had an EGR system. So, Toyota did some weird things trying to deal with the various smog mandates. :)
Interesting, thanks. A PO could have easily removed mine.
