Can Only Remove Key From Ignition If I Disconnect Battery
Anarchy
GOLD Star
USA/Canada
I’ve searched the forums and although there were many threads with ignition key stuck issues, I wasn’t able to find something as specific as mine.
I can put the key in the ignition cylinder, turn the vehicle on & turn it off, turn it to ACC, and turn it to lock. But I cannot remove the key from the cylinder unless I disconnect the battery.
I thought it may be a shift lock solenoid issue but I can start, shift, drive and turn the key to all positions, just can’t take it out unless I disconnect the battery.
I don’t believe this is a ignition cylinder issue either, what do you reckon it could be?
Key interlock solenoid or shift lock ECU would be my guess.
Did you ever find out? I'm having a similar problem. I replaced both key interlock and shift interlock solenoids.
