Can one use a Hi-lift with an 80?
e9999
Gotta get out there...
Moderator
US
is it possible to use a Hi-lift jack on an 80 that does not have heavy-duty bumpers?
If so, what part of the truck do you lift with?
thx
Eric
all right, all right, no ARB nor Slee bumpers, bull bar, no slider, nothing. Just stock...
Possible?
where?
E
uh, you can, but it 'could' be a tad more dangerous. I guess the question is WHY would you want to?
cuz I'm feelin' the urge to get one! They are sooooo cruiserish!
But it'd be a bummer if I can't use it, eh?
E
not to mention it might get me out of a sinkhole someday, eh?
If you are not wheeling with the junk on your rig, then they are a dangerous toy. Check the thread in Outfitting. They can be VERY dangerous and they can also be considered mission critical by some. I have rarely used mine for other than changing tires or swapping suspension. I greatly prefer the 2 bottle jacks I normally carry - replaced the stock with a pump bottle jack from Sears and also have an air bottle jack - I modified it and it has 20 ton capacity.
I'd have to agree with the moderator on this one :rolleyes:
I've had the same hi-lift since 1988 while going through 2 40's, 2 minitrucks, 1 60 and now an 80 and I've only ever used it to pull fence posts.
I've also personally witnessed one KO a guy a little careless with that handle when under pressure - folks that have used them KNOW what I'm talking about.
Just my two cents.
Mike R.
Have you ever seen the cartoons where the guy gets whacked several times with a jack...that's where it comes from. If your not going to modify your rig, there's little point in buying one. Or you use it on the stock bumper and scar the hell out of it and then upgrade to something better.
[quote author=clownmidget link=board=2;threadid=15482;start=msg146542#msg146542 date=1083124759]
[/quote]
Been there done that. There is nothing more sublime then watching a J#@p owner try to figure out how the hell to use said instrument of destruction , err I mean extraction.
You would think that if somebody strapped one of those things on their rigs, and rolled with it for a couple of years they would at least know how to use it. ::)
Unless you plan on wheeling alone, or you work on a farm, chances are you probably never need one. There are plentiful on most trails, since everyone deems it necessary to have one or two at all times. Furthermore if you have one where do you plan on putting it? If it’s as stockish rig as you say it is, you will be hard pressed to find a nice location for it to oxidize until you actually need it. Those mofo's are HEAVY.
:cheers:
n
[quote author=moralien link=board=2;threadid=15482;start=msg146568#msg146568 date=1083126888]
[/quote]
You know....That brings me to a good point. I was in the process of modifying a rear bumper and trying to incorporate a "Slee-Type-Mount" on one of the swing aways and it just wasn't working. Plus I really didn't want it outside anyway. So I found a spot that works perfect. Open the back up and fold the DS 3rd and middle seat. Put the bottom of the jack at the back of the rig and the top up under the middle seat. This allows the jack to lay flat and the middle row to fold back down. I haven't put the third row seat back in in yet to see how it will clear, but it looks like it will be fine, plus I don't wheel with it in the rig anyway. It doesn't shuffle about because it's pinched in place and it's out of the elements....and it's the BIG MOFO 60 inch jack.
Pics for anyone who cares...
p.s. You can see how much I've used it. :flipoff2:
I've wheeled alone for years in my 60, well not exactly alone, just the wife and kids, but that's pretty much alone ::)
Anyway I've found it useful to just carry a bottle jack and also a come-along (hand winch and tow strap). I wheel in wooded areas pretty much and in a pinch it's enough to get you started.
Now in the 80 I hope to never need the hand winch.
Hi-Lifts are for serious wheeling deals and suspension work on lifted trucks.
I would steer clear and get bottle jacks until you need one.
Since I don't have a winch I've been considering one. They're not very expensive at TSC. I agree with most folks that it seems like a dangerous alternative to the bottle back if working on your rig. Does look like a good tool to help if you're the vehicle on the trail.
Here's a link to a "how to use a hilift"
http://www.4x4now.com/bb0997.htm
so, there really is nowhere to put this thing on a stock 80 without damaging something while jacking it up? Not even tow receiver frame?
E
I have one on my (stock) 80 and haven't had to use it. I also had one on my 60. Thge best (only?) place to use it on stock front or rear bumpers is where the frame rails plug into the bumper.
There's a guy in my club that's made a little piece of plywood that he uses to jack around the sills (not on an 80) - I can't remember how it works, but he did use it to jack-up his truck on the side. I'm not sure of the 80 has this, but oin my Jetta there are two points on each sill that are reinforced for jacking (it's a screw jack that attaches to the sill)
As others have noted, the problem is that they are very 'tippy' when you are jacked up (some use this 'function' to help extract stuck trucks...it works, but be prepared to go to Emergency...or worse...). If you are using it off road, make sure you have a nice wide base (ie 2x2 - or more - thick plywood) to distribute the load and keep it from sinking.
My suggestion for those that haven't used one is to put the 80 on a level piece of pavement and jack it up a little. Then see how it works to lower, etc.
use a bottle jack whenever you can and try a tug or a winch first if you get stuck. Even if you add an ARB you will find it hard to find a secure place to put a hi-lift or jack all (I have used it on the arb cross bars in a pinch). There is an extension arm accessory that would enable you to lift an 80 from the frame from the side, but I don't know about stability because of the length of the arm. You can jack up using the tow hitch receiver hole in a pinch but it acts as a fulcrum for the truck to tilt on and is not stable. Basically this is an emergency tool to be use with extreme caution.
Sort of off subject, but in terms of storage, I recently ordered the Slee Hi-Lift roof rack mounts and I am impressed with them (as I am with all of Slee's products). With the lift on the roof, I have so much more space in the cabin. Well, not really so much more space but so many more ways that the cargo can arrange; prior to purchasing the mounts, I had to secure the lift to the floor and the brackets that hold the third row seats in place. This made the lift tight but then I had so much stuff on top of it that if I did need it, I would have to unload so much stuff to get to it. The roof rack mounts are much better. HTH
