Can I use this grease for hub rebuild?
I'd use synthetics, particularly if you're in a part of AK that gets chilly. :)
True synthetic lubricants (by "true" I mean products not derived from dinosaurs and given the name just to get the high bucks) are, IMO, superior in every way to petroleum based lubricants.
Formula one racers, all aircraft manufacturers, and the US military services can't ALL be wrong. Synthetics are the future....now.
I understand synthetics can provide certain desireable charachteristics because they are made in laboratory versus mother nature. I run them in all my newer vehicles and motorcycles. However, my never-leaked-a-drop mid 80's 350 leaked like a sieve on Mobil 1 10W40. Back to dino and it's dry as a bone.
Cannot run Full synthetic in a motor that has not run it from the git go. It will just blow by the rings and it's a lot thinner. 0-50k is ok to start with. Over 50k you need to use a blend. Otherwise you will be just wasting money having to keep topping off.
I have approx 5K miles since a major and ran 10W40 dino for the first 4K. Switched to synthetic and it leaked like a mother. Pokes a hole in your argument :)
Blends are waste of money. Either run full synthetic or use a good dino or diesel oil. I use Rotella dino in all the cruisers and I'm switching to Rotella synthetic 5W-40 from Mobil 1 in the Rodeo.
Not true. it's best to run a non-synthetic oil in a new engine for the first 5000 miles (some advise 15000 miles) so that friction can allow a good break in. If synth oil is run from the start the rings will never seat.
Synthetic oil does sometimes bring leaking for a while. Usually the leaks stop after a little while.
I changed to synthetic in my DD (at 90K) First change it used a little more, next change didn't use any. I'm also running it at 10K oil change, new filter at 5. Mobile 1 10-30
But to answer his question, YES, you can use that grease. I use a thinner sythetic on my hubs (amsoil thin purple stuff). Just lightly paint it on the slip surfaces/splines/threads
dgangle said:
Then how does it work in new cars that come from the manufaturer with Synthetic oil? Different machining? Not.
Prolly an additive that helps break in. Kinda like assembly lube for a cam, maybe? I was always told that it had an abbrasive in it.
Synthetic will allow the rings to seat, it just takes longer.
Yeah, Porsche worked it out :)
Cummins recommends waiting for the reason stated but I'm sure that the manufacturers consider all aspects and friction elements, and did before ever putting synthetics in as original fill.
