can i roll down my automatic windows manually? (1 Viewer)
Pagosa Springs, CO
hey I'm turning my FJ62 into my dream come true! Im painting it, inside and out!! But, i did a dumb thing, i took the doors off and undid the wire harness before rolling the windows down to take them out. is there any way to manually roll them down (off the truck)? Or am i just being lazy and need to re-install the doors and panels to roll them down? Any suggestions would be greatly appreciated!!
can you put 12v to the motor and just hold the circuit till its down? don't see why not...
I thought he meant some thing else. Yea you can hook up a single wire to a 12 volt source and then reverse the leads to bring the back up.
Yeah, a cordless drill or equivilent battery will do the job with a couple jumper wires.
Not sure you need them down to remove them... Access to the bolts is the important part. Sadly the FSM doesn't specify up or down
Tony
