Can i bring this acutator back from the dead fjz80 rear acutator fun!
St louis
So the deal is, this acutator was shot! Posting this mainly so if anyone needs another reference and to show that no matter how bad it looks , it could work. I'll let you know Sunday funday! Bi-directional springs rusted together , actuator rod froze in case, worm gear froze in bearing that was shot , capacitors were broke free from their soldered spots , and of course magnets were unattached . What's crazy is there is literally no rust under this thing. I suppose the vent tube(was attached when I pulled actuator ) was broke somewhere else up the line and allowed moisture. On to the craptacular photos.
If you do a search, you'll find some threads that'll show you some rusted actuators that were in way worse condition then yours, that were brought back from the dead.
witsend sells a rebuild kit from landtank couple orings etc. cheap
I picked up the wits end kit. Had to pick up the z608 bearing and the capacitors separate.
Yea Im surprised Joey dosent have the full rebuild avail.
The capacitors i kind of guessed on, couldnt get an exact match because mine were broke, and every thread I went through didnt have a part number or a good enough pic for reference . The bearings are literally less than a buck at fastenal.
After cleaning and rebuilding mine it now works.. I'd say yours appears to be in better shape then mine was.. Good luck!
WkleHjopbzgKCdyqS4NyvHzj7NbvfT8zKZ1FFTFiMoQhZ0yzSVuGl7DHWcmSswv8xN-no-FPzhWB_UThNvxkuU71ejzqWZklFleSrRqX_LeVvMvY4DMRUr-gdQvfcP-eBzB7yAcWrKxh8urmdLicvPcbIP0p6ZLndsdp7XtqYnvlH_hDuaJSFZ-1sGUFtrV4ZWcMLWWvu1Kf33N2Q8qm0IfSUHHZR9lDNPKvLSD3URiqPEMQM_MlMh8Z1QSDHaCiA8qlAWLCC2XYlX2vTtPT-qWypgiVVVYcqe67YWe2ySUxRm43-Hqx8VFXDWLVEFJlzWKX29foZk6VzXmjUfyofsW99KIUX5FXf84kHoTj6CKF7-dKzmXTgKvotu6kd2tRcU1x6N6f0JiSiSUtlIj-nbXStnyyOMer5D7OZijhLEV_0NLouq1Wusix0npjPQwBchErK-UtM_-a0B2eZ2vr2gWEut8qGAwpdWVZvbD21j3CJPyqeNaHILgNfJuEGkeblzjYdQGMrz5CPzKkWKWaiNowjo-rtBhcgvReJBLzWA7BsRsKj_v41maIMOCeUHaK7DpsLkK6kj3Jzys7QIjSwh4Al8gyycws-vWCvpDFLVx6lFqymgvtekrO5aOemP6Fe1SXJQZhnFWihfWRjCg5IPALQLPYUjji=w1470-h830-no
No one upping on s***iness of rear actuators lol. In fairness , the photos I posted were after parts(all the metals at least) sitting in atf for a week .
Ok, rookie question here. Why not have a lever / knob / cable actuated front and rear diff locker? Eliminate the electric actuator? Yes, it would suck crawling under the vehicle to lock / unlock the front and rear diffs - but reliable has HELL!
Just a thought for the day.
This has been done. A few years ago I read where one or several had climbed that mountain and with pics etc.
