I did the search on 24 to 12 vdc charging and I just finished the wiring, connections, terminations.
What I need to know is how a 12.06 VDC output of my 24/12 converter will charge my 3rd (12 volt system) battery?
The max charge on a batter is around 12.8 volts. my 110 AC to 12 VDc battery charger outputs 13.3 volts when it is charging. Is it possible for the battery to get a complete charge with a voltage of 12.06 out of the converter?
The converter is only on when the engine is running via a relay, so no worry about the 2 batteries equalizing into the 3rd stand alone.
