Cam Work (1 Viewer)
N
nyk438
Guest
The cam on my 91' 80 is going. The valves on the cruiser had been loose for a very long time and from what the shop says taht caused the wearing of the cam. I was told it takes about 12 hours of labor to change the cam which would cost around $800 plus $250 for the cam. Does it take 12 hours of labor to change out the cam?
Why do you say the cam is worn? What symptoms are you having?
I don't have any 3FE experience. If you're going to spend $1000 on the motor and only get a new cam, it seems to me you should just rebuild it.
Don't they ahve to rebuild the engine basically to replace it?
The cam in a 3FE is burried deep.
Do not forget to replace the lifters too. Old lifters on a new cam is poison.
Cam, 13511-60060, list $423.49
Lifters, 13751-61020, list $14.60 each x12
Uhg, so I'm paying mostly labor bah.
LCS said I had 20k miles left on it so I'll just start saving now hopefully I'll have the money before it dies on me.
CDan would you know how much a front driveshaft for my 91' 80 would cost me?
i got my valves adjusted (or whatever the aficionados will call it) on my '91 at 175K -- it's at 200K now and purrrrrrrsssss
e
My valves adjusted sounds ten times better...no more sewing machine under the hood.
