Cam/Crank & Main Bearings, Piston rings...reuse?
Dallas
Website
www.octagonmma.com
I have the engine torn down and the cam/crank journals look fine, as do the all the bearings. Do I just reinstall and run them or replace them all even if there seems to be nothing unusual going on? Cylinders are all nicely cross hatched still though all the pistons have some light scoring on one side. Nothing you can feel but there are some fine marks. I tried to photograph them as well as the cylinders but they didn't come out that great.....:mad:
Also what is the general rule on piston rings? Go new or run them if they are ok?
My take on this is to run it as is with only necessary repairs made, until it croaks and put all the $ I would spend totally rebuilding it into a new engine. I did get an OE gasket rebuild kit, air rail plugs, 3FE timing endplate torx, and manifold studs from CDan yesterday.....
Why did you tear it down?
I would replace the wear parts like bearings. A full set is pretty cheap.
you have already done the hard part...do not half ass it now! do all bearings, rings and wearable parts now if you want a solid truck...the worst thing that could happen would be to spend all this time and $$ and then have to do it AGAIN because you tried to save a few bucks.
Just my .02:grinpimp:
The rings and bearings should be ordered from whom? I have no idea who makes good ones.
Toyota
MAF
SOR
I used a set of rod bearings from SOR that have been just fine, but Japanese aftermarket. You might check with Jim C on the best rings.
I can buy a 3F engine for the cost of that set of rings and bearings, btw.......
