Calling all burping experts..
Discussion in '60-Series Wagons' started by frank boone, Aug 23, 2006.
  1. frank boone
    frank boone
    18
    Jun 12, 2006
    Put down the PBR, it's not that kinda thread.:doh:
    My question is how long does it take to get all of the trapped air out of the radiator and cooling system? I spent about 15 minutes with the heaters on high and the cap off and it bubbled the whole time non stop. It almost seemed like there was air getting in somewhere. My fan clutch and tstat are good and it overheates at idle only. What the?
  2. High Desert
    High Desert
    1,227
    2
    Mar 21, 2005
    Central Oregon
    Make surre the nose is up higher than the rear. If it is still bubbling that should chase it out. make sure the radiator is a full as it can be with out sloshing out
    as it flows. have the resivoir at the right levels.
    If it an't leaking out any where then air is not getting in anywhere. I changed out a rear heater hose, the really short turned ones at the heater underneath, took to "burping" sessions to get it straightened out...
  3. frank boone
    frank boone
    18
    Jun 12, 2006
    Thanks. I didnt have the front lifted up. ill try that.
  4. Mungoon
    Mungoon
    59
    Jun 14, 2005
    Whitefish, Montana
    Dang, I thought there was finally going to be a thread on this forum where I could be considered an expert.
  5. Dynosoar
    Dynosoar Slightly Disturbed SILVER Star
    3,700
    382
    Feb 4, 2006
    SoCal
    Overheats at idle! Replace radiator cap and fan clutch (OEM only on fan clutch)
    Dynosoar
  6. MJM
    MJM SILVER Star
    793
    35
    Feb 26, 2003
    Next to the Falls in OH
    Get the Front UP
    It will take some time but get the front UP!
  7. mrsvle
    mrsvle
    183
    Jan 8, 2006
    Tucson, AZ
    Yes, keep the front elevated, you can park it on an incline. Also, with the radiator cap off you can squeeze the top radiator hose periodically to force out any air. matt
  8. Aseif007
    Aseif007
    969
    Albums:
    1
    11
    Mar 13, 2004
    Northern California
    THis is the method I used and it worked very well.
  9. lunyou
    lunyou
    2,403
    3
    Oct 24, 2005
    Cuba, MO
    i have a stupid question.......my 60 dosent' have the rear heater hoses hooked up....is this okay??? Any reprocussions.
    lunyou
  10. frank boone
    frank boone
    18
    Jun 12, 2006
    Tried it today and same thing. It bubbled more than a bong at college. I lifted the front and it wont stop bubbling. Is there really that much air in there? Grrr. Can't figure this out and im going wheeling saturday.
  11. Aseif007
    Aseif007
    969
    Albums:
    1
    11
    Mar 13, 2004
    Northern California
    What I did was wait until the t-stat opened fully then shut off the car in my slanted driveway, with the front up higher. I would then squeeze the upper radiator hose with the radiator cap off (pushing/bubbling out some air) and while the hose was squeezed I would pour in coolant and slowly release the hose which would suck more coolant in. When I released the hose completely I would squeeze again pushing out more air, then pour more coolant in while releasing the hose. I did this until I could no longer bubble any air out. It was not a quick process so be patient. Then I would take it for a spin and then come back and do the whole process over again until I was completely full of coolant. Remember the hose will be hot, and this is a tedious process.
    This may not be the best way to do this, its just the way I did it last. Good luck.
  12. nuclearlemon
    nuclearlemon not an addict Moderator
    16,070
    Media:
    87
    Albums:
    4
    885
    Jan 30, 2003
    meh-ico, colorado
    unlike my 40's, my 60 has always taken forever to burp
  13. Trollhole
    Trollhole THC Supporting Vendor Moderator
    20,795
    Media:
    79
    Albums:
    4
    2,626
    Mar 6, 2005
    Mauldin, SC
    Possible blown head gasket? Could explain over heating issue. Any white smoke? Does the radiator fluid fizz like coke?
  14. 60wag
    60wag SILVER Star
    1,926
    39
    Jun 25, 2003
    Boulder, CO
    My standard answer: put a Pestone flush T in the heater hose near the heater conrol valve to vent the air - easy and quick.
    The continuing stream of bubbles does appear to be a possible head gasket issue. Put the cap on the rad and drive it around to get it fully warmed up. Hopefully it'll mantain a proper temp. Let it fully cool off over night then start it in the morning with an assistant checking the exhaust for white smoke. Keep your fingers crossed.
  15. pvidrummer
    pvidrummer
    192
    1
    May 15, 2006
    Puerto Rico
    When I got my FJ60 it was overheating at idle. what I did to remedy this problem was a simple flushing and cleaning of the coolant system. I used two bottles of chevron radiator cleaner, at the same time. It removed lots of sludge and debris from the radiator and completely solved my overheating problems. I dunno about the burping I have never had problems with that. Maybe you are doing it wrong?
    If you want to eliminate any doubt that the head gasket is fried, try these tests.
    Check the oil dipstick for a brown sludge instead of oil. You can check the piston compression too. Check the spark plugs. The radiator sniffer test is a nother way to go. Like 60wag said, check the exhaust for white smoke.
    I think that the most effective method to diagnose a bad head gasket is by checking the piston compression.
    Good Luck.
