Calling all Aussies! Troopy parts questions
Seattle, WA
Website
www.4wdtoyotaowner.com
G'day gents,
I have an early Aussie HJ47 with the 2H. It's got the dual fuel filter setup and also the two oil filters (upper being the centrifugal unit)
Do you folks have access to parts numbers to the element-style fuel filters used in the earlier 2Hs? meaning, it's not a screw-in filter, but an element inside the metal housings.
Also, a part number for the centrifugal oil filter and O-ring/gasket?
Thanks all!
Dave
If you give me the year I can look in my EPC.
Also, toyodiy.com is a great source.
I took mine to a repco and there database had everything that i needed, i would say that any local auto shop around you would either have them or be able to get them. Where in aus are you.
I have since changed diesel filter though.
Dave's in the US of A Kai.
(Seattle in Washington State).
So no access to Repco and only restricted-access to toyodiy.com too.
:beer:
heya all,
Yes, near Seattle. The year is 1980, VIN is HJ47000007 if that helps too. Cheers,
Dave
That dual fuel filter looks like it is a single metal body with 2 separate filters on it right?
It didn't recognize your VIN so I looked at an 1981 HJ47 and it listed this part# for the fuel filters: 04234‑68010
Googled to see what it looked like to make sure it's correct:
Toyota Diesel Fuel Filter 04234-68010 - Detailed info for Toyota Diesel Fuel Filter 04234-68010,04234-68010,Toyota Diesel Fuel Filter 04234-68010,04234-68010 on Alibaba.com
The O-ring seal for the centrifugal oil filter should be this one: 15535‑77010
Or it's this one: 15545‑77010
The first one sits inside the filter, the second one sits near that clamp that holds the filter onto the body. Looks like the first one is included when you buy the filter itself. So most likely it's the second one.
The centrifugal filter itself is this one: 15504‑77010
Quite an expensive one apparantly, 156 bucks...(at the dealer)
Those should be it.
:beer:
Sorry about that, i just saw the WA and thought Western Australia. Haha. Good luck with the parts hunt
Oil filter # 1: 15601-68010--spin on (available in the US): List: $13.12
Centrifugal oil filter element: 15504-77010 (not available in the US)
oring: 15545-77010 (not available in US)
gasket: 15551-77010 (not available in US)
Fuel filter element: 04234-68010 List: $15.03 (available in the US).
:cheers;
Thanks Beno and everyone who responded!
Dave
