Hey guys,
Short version: What do i need to put lockers from a 60 series axle and install it in a 40 series axle?
Long version:
I need some help before i pull the trigger on some 60 series axles with cable lockers.
First off: i have a '84 Bj42.
If i would want to take the lockers from the 60 series axle and install them in the 40 series axles, what else will i need?
I know that the 60 series axles are 70mm wider, but i need to know what exactly is different so i know if i can use my 40 axles if the condition of the 60's are not that good..
I believe that the "Axle" inside the housing (missing the english term atm) is longer in the 60 series where it inserts in to the locker, can i use the parts from the 60?
Btw, the 60 series axles fit under a 40, besides from the extra 3.5cm on each side, right?
Other than that they are the same?
Best regards!
Long version:
Best regards!
