I have an HDJ81 (RHD auto) which means conveniently, there is a ~36mm hole (plugged with a rubber grommet) right through the bulkhead where a clutch master cylinder would have been fitted.
I had the idea of using a 36mm gland and 21mm convoluted tubing in which to run cables from the engine bay into the cabin which has the benefit of easily being able to add cables in the future when required.
My only concern is how close it is to the exhaust manifold and turbo.
The gland is made of nylon and has a working temp of 100c.
Would this stand the heat or will I need to shield it somehow?
