supdizzle
Bump for a great write up! Fixed my issue, thank you!!
3: The inboard hinge pin is OK, but I cannot see any way to remove the door from the blower housing without taking the whole darned thing out of the dash. I have tried carefully prying on the interfering part (to the right of the leaf) and there is no way I can flex the parts enough to get the pin to clear.
It is possible with patience to get the door out of the assembly without removing the whole assembly (doing it by the book requires removing the dash). I did it. I couldn’t get enough flex either, so I took a fillet knife, heated it with a propane torch, and cut/melted away some of the blower housing and made some clearance. View attachment 2064087
After getting the flap out I glued and safety wired it back together.
The glue I used came from 3M. Through work I know a 3M adhesives application engineer. He came over on his lunch break and walked me through the two products he’d recommend and then helped me glue it all back together. These are the products he recommended. He and I used the 8010, but he said the other two products used together should be fine too. Epoxy and JB weld won’t stick to the low surface energy plastic Toyota used for this part. These products will. This type of plastic is also easily weldable if that is appealing.
Getting the door back in was the hardest part. Eventually I folded in the seal and just pushed the whole thing straight in the housing window. I tore the seal slightly. Some lube might have helped.
HTH, Ken.
Does cutting up the housing like that allow air to bypass the filter?
The threads on this topic had me nervous. So I did this before my appointment this morning. Thanks for the heads up!
The last sticker needs to be added that says "Yes, you will the screw driver, step back"........The threads on this topic had me nervous. So I did this before my appointment this morning. Thanks for the heads up!
Done - added to the maintenance sectionThis thread and
IMPORTANT: Check your HVAC recirculate door and answer Poll
This is REALLY important, it affects how well your system defogs in winter and cools in summer, and if a small amount of damage is caught early it could save you MANY hundreds of dollars. My door hinge is busted, probably by somebody who forced it open, not understanding how to correctly access...forum.ih8mud.com
Should be in FAQ.
Maybe @Romer will consider adding them.
HTH, Ken.
