Hi!
I need some help determining where to go next. Very Bouncy ride. I replaced my rear globes and AHC fluid first (ok I see that was a mistake) but I figured it was the big wear part. I have 178Kmi and I replaced the globes at 120K. Also I could feel a dramatic thud when I back off a curb on the rear wheels. The sport to comfort selector on the AHC seems to do nothing, but I did slam on the brakes and can feel a slight difference there.
First off and likely most importantly, I have the following two trouble codes: C1721 Damping force Control Actuator FR Circuit and C1723 Damping force Control Actuator RR Circuit. I saw the thread about the exhaust leak and shorted wires. I don't have an exhaust leak as far as I can hear and I peeked at the connectors and they are not melted. This is not a through inspection, but it seemed ok at first glance.
Should I disconnect the actuators and check resistance first? Then the next step is to disconnect at the AHC ECU and check for shorts to ground or between the wires? I can see I need to adjust my level sensors and my torsion bars, but that is not my primary issue.
Also and not that important - I disconnect my AHC reservoir heater the AHC system deactivates. Its and 06 LX. I was disconnecting to get better pressures as YotoMD recommended. Should it be deactivating?
My measurements are as follows:
FL = 19-3/8"
FR = 19-15/16"
RL = 21-7/8"
RR = 22-7/16"
N position:
FR Sensor = 0.1
FL Sensor = -0.5
RR (rear?) Sensor = 0.1
Front = 4.0 Mpa
Rear = 8.3 Mpa
Accumulator = 10.6 Mpa
Thanks all!!!
FL = 19-3/8"
FR = 19-15/16"
RL = 21-7/8"
RR = 22-7/16"
N position:
FR Sensor = 0.1
FL Sensor = -0.5
Front = 4.0 Mpa
Rear = 8.3 Mpa
Thanks all!!!
