I noticed the photo links are all broken. I have attached a photo of the proper orientation of the cam when properly installed.
(It's not the end of world if you get it 180 degrees wrong. Just pull off the white plastic portion and rotate it)
I have attached a picture of the screw driver length that seemed to work best for the job. It is a number 2 Phillips.
(I know kinda cheesy to post a screw driver pic).
Also we found the key cylinders get really chunky if you clean it with wd-40. We were able to get it working smoothly again by applying powdered graphite and working the key back and forth.
Also it helps to have great friends like Treeroot and Simps80 that show up at the house and do most of the work for you.
