burning huge amont of oil/ oil catch can full (2 Viewers)
ST8ROCKS
Kevin
Beaufort NC
My 91 has always burned a large amount of oil so I put a catch can on it. After driving for 30
Minutes the catch can is almost full!!! Any ideas of what could be causing this or where to start looking?
Is your PCV valve working properly?
Yep blue smoke and PCv replaced a month ago
Not meaning to sound insulting, it's happened to me before, but...
Did you install the the PCv in the right direction?
:whoops:
No worries. Pcv was installed in the right direction don't know how you could get that mixed up.
Also as I stated this is not a new issue. I put a quart in every week
glazed cylinder walls or bad rings or valve guide seals, valve guide seals can be repaired w/out removing head. A compression check might help give you an idea where the problem is.
